How to create phone number as links in notes of Contacts
falcios
Can we create a phone number link in the notes of Outlook so that iPhone can recognize it as a phone number to dial?
Thanks in advance.
falcios
Thanks Diane for your response.
I've entered the phone number <tel:1111111> and hit enter and it underlined it in the notes but when I select on the iPhone it doesn't dial. There is no underline in the notes on the iPhone.
Any other suggestions to try?
I think if you prefix it with tel: it might be linkable - you may need to put it inside brackets too. <tel:10digitnumber>
If tel: doesnt work, we need to find out what prefix iPhone uses to detect.
Diane Poremsky Create a Task when a Message is Flagged Using Outlook 0
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
Mark White vba to create a shared mailbox folder Outlook VBA and Custom Forms 3
Diane Poremsky Automatically create a task when sending a message Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
Diane Poremsky Create a Series of Tasks using VBA Using Outlook 0
J create .pst data file for new gmail account Using Outlook.com accounts in Outlook 1
