Detect Google Drive and OneDrive links in incoming mail
gruiz
Hello everyone! Security policies don't let me open Google Drive and OneDrive links at work, although I can see them on the email (don't ask... can't change that).
How can I detect this incoming emails to warn the sender that I didn't got his attached files? They believe the files arrived safe because no email is bounced and in fact the email arrived safely but not the attached files.
I can do that manually looking at each email but its a time consuming task. I saw that Google Drive shows as links that contains "drive.google" somewhere in the html and OneDrive are small files with .drv extension.
I would like to use VBA in Outlook to automatically send a reply with some predefined text replying that I didn't get those files and they must be sent as an attachment
You can use a run a script rule or itemadd macro - i'd probably use instr function and look for keywords in the body
strbody = item.body
if instr(1,strbody, "drive.google") > 0 or if instr(1,strbody, ".drv") > 0 then
'send reply
end if
This page has a sample macro for sending the reply
gruiz
Thanks Diane! I'll further investigate since I need to apply it to emails already received. I'm using Access VBA from quite a long time, but Outlook's is a little bit different.
It seems that I would be some time reading all Outlook related things at slipstick.com to achieve what I want.
Is there any reading you can recommend me to get in touch with the Outlook VBA object model? Reading MS documentation right now but I mean real examples and not just properties and methods.
Thanks again!
Outlookcode.com had a lot of information but it's been offline for a while now.
Do you want to always run it yourself on selected messages? It's not difficult to change a run a script rule to manual - or to use both.
Use a 'stub macro' to trigger the script or replace 'YourMacroName objItem' with the code that does what you need. You need to make sure the object names match up - which you should know from Access VBA.
Sub RunScript()
Set objApp = Application
T VBA outlook, detect priority emails Outlook VBA and Custom Forms 5
20 Ton Squirrel Detect Application_Startup event completion Outlook VBA and Custom Forms 1
M Outlook 2003 rule to detect a blank category Using Outlook 1
B Can not start Microsoft Office Outlook. Errors have been detect in the file. It said, close Outlook Using Outlook 1
P Outlook 2010 does not detect Proxy Settings with an ISA Client Using Outlook 2
G detect if a mail is read in a public folder Outlook VBA and Custom Forms 14
M Another way to detect if email read? Outlook VBA and Custom Forms 6
M how to detect duplicate email messages? Using Outlook 5
A how to detect email is saved to draft? Outlook VBA and Custom Forms 3
J Detect logoff/shutdown Outlook VBA and Custom Forms 1
H How to get BCM in OUtlook 2007 on Vista to detect my MDF file? BCM (Business Contact Manager) 1
GregS Outlook 365 blocked by Google popup Using Outlook 2
TomHuckstep Outlook 2016 Limit the number of days syncing from Google Calendar Using Outlook 1
G Outlook VBA and Google Calendar ("Events") Outlook VBA and Custom Forms 1
D launching a link in google Using Outlook 1
Horsepower Google says Outlook 2016 is not a secure app Using Outlook 4
C Search with Google Macro? Outlook VBA and Custom Forms 4
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
M Google Apps Mail *SENT* from iPhone doesn't download to Outlook via POP3 Using Outlook 1
T bcc and Google imap Using Outlook 3
B synching outlook 2010 with google on android phone Using Outlook 6
C Odd error message not found in Google search Using Outlook 1
A Outlook 2013 IMAP using Google Mail App not syching Sent Mail Using Outlook 3
C Setting up Outlook 10 on Widows 8 using Google Server Using Outlook 3
A Recommend add-on or utility enabling quick Google search within Outlook Using Outlook 7
D Outlook/Google Configuration Using Outlook 27
S too difficult of a question to google Using Outlook 2
billzant RSS feeds and google Using Outlook 2
M How do I change the default map from Bing to Google in Outlook 2003? Using Outlook 23
I Links not working after un-installing Google Chrome Using Outlook 2
J Outlook Connector equivalent for Google Mail? Using Outlook.com accounts in Outlook 2
D Outlook 2010 registry hack - delete emails - Google Apps Using Outlook 0
R Outlook and google calendar stuck if I close outlook Using Outlook 1
C Sync Outlook Calendar and Google Calendar Using Outlook 1
L trying to download a google app that alows me to sync outlook with the droid x. Can you assist me in the process? Using Outlook 1
D syncing emails from google Using Outlook 4
H Lost ability to sync MS Outlook 2007 Calendar and Google Calendar Using Outlook 4
F Google Desktop fails to index Outlook 2010 Using Outlook 3
C Unlinking outlook with google calander Using Outlook 1
J importing google contacts into outlook Using Outlook 1
C Having issues with Google Desktop and Outlook 2010 mail: Using Outlook 1
S Broken hyperlinks by uninstalling Google Chrome! Using Outlook 2
J Contacts (sync'd with Google Apps) won't connect to address book Using Outlook 1
A Creating a shared calendar across small local network that also sync's with Google Calendar online Using Outlook 1
R MS Outlook will not connect to Google's mail system. Using Outlook 2
B Using Outlook 2007 (and 2003) running on Windows XP with Google Apps IMAP accounts getting "An unkno Using Outlook 1
M Problems receving Google mail (based in Greece) to Google mail (based in UK) via Outlook Using Outlook 1
