Rule for "on behalf of" - with changing names
neyoneit
id like to make a rule for emails received "on behalf of" but the names are different everytime.
I have found Rule to sort out “on behalf of” messages - MSOutlook.info but it wont work for my situation, because right after on behalf of there is a name mentioned again and everytime different one.
for example
Peter Bole <peterb@seznam.cz>; za uživatele; Peter Bole <info@thisemail.test>
Jacob Teler <jacobt@seznam.cz>; za uživatele; Jacob Teler<info@thisemail.test>
(za uživatele - on behalf of)
Thanks for help,
neyoneit
shoot - I forgot to set up a test to see what could be possible. i think you will need to use a macro to do it - my thought is we will need to compare two properties and if different, its on behalf. I don't know if this will result in "false positives" for newsletters etc.
N Autoresponder won't send to 'noreply@...' and need to change rule to send to on behalf person. Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
Ascar_CT Rule behavior analysis - any tools available? Using Outlook 0
Liza Creating a rule in outlook to filter messages Using Outlook 0
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
B custome rule Outlook VBA and Custom Forms 2
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
Diane Poremsky Create a Task from an Email using a Rule New Slipstick.com Articles 0
M Rule option Using Outlook 2
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Transactional emails - mail rule Using Outlook 3
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
