Programmatically force html send and insert clipboard contents into body
bcmarshall
Users on my 20+ user MSAccess 2013/SQLServer 2016 system occasionally encounter errors. While the error message is open I would like my users to manually hit ALT+PRTSCN to copy a screenshot of the error message to clipboard.
I want to provide them with a button on the Access form that generates an email to me. I want that click, without any intervention by the user, to open a new mail with my address, pre-populated subject line, and pasting the clipboard contents into the body of the mail as an image rather than an attachment. They should be able to add descriptive text as needed as well.
Ideally, this is a one-click operation. They copy and close the error message and then hit my send button, and the mail is generated, the image is pasted into the body, and except for any text they may want to add it's ready to go.
Does anyone know how to accomplish this in VBA from Access?
Dr. Demento Programmatically encrypt email (2010) Using Outlook 10
oliv- Reduce the size of picture attachments: programmatically Outlook VBA and Custom Forms 3
B Adding controls programmatically Using Outlook 1
M programmatically make all Appointmentitem olResource Attendees unsendable Using Outlook 1
S Programmatically accessing Outlook Calendar data Using Outlook 1
R Send appointments data to a Form programmatically Outlook VBA and Custom Forms 2
M How to connect to SQL DB from outlook programmatically? Outlook VBA and Custom Forms 1
B Programmatically scheduling WebEx meetings through Outlook Outlook VBA and Custom Forms 1
N Help in programmatically setting formatting in an AppointmentItem Outlook VBA and Custom Forms 3
K Programmatically accessing Outlook properties Outlook VBA and Custom Forms 3
V How to programmatically set "Display reminders and tasks frm pstfolder Outlook VBA and Custom Forms 1
R Displaying a field from the field chooser programmatically Outlook VBA and Custom Forms 1
M How to programmatically select a outlook search folder? Outlook VBA and Custom Forms 1
M How to install custom mapi form programmatically? Outlook VBA and Custom Forms 1
A Programmatically duplicating BCM's "Link to Record" function BCM (Business Contact Manager) 2
B Accessing Outlook 2003 Signature Programmatically using C# Outlook VBA and Custom Forms 6
L Programmatically moving between pages in a form Outlook VBA and Custom Forms 2
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
S assign task programmatically Outlook VBA and Custom Forms 2
S do Reply, Reply to All, Forward programmatically Outlook VBA and Custom Forms 2
J Force account selection for sending reply emails Using Outlook 1
C Force account selection - no reg path nor can create one Using Outlook 9
D How to force full message download for all Gmail messages in all folders with IMAP in Outlook 2013 Using Outlook 1
S Force Outlook to use TCP Using Outlook 1
C Defer email delivery - but when force sent using F9 Using Outlook 1
R Force use of general outbox Using Outlook 1
F force new meetings and appointments to send from my IMAP account Using Outlook 7
A How can I force Outlook 2003 to use A4 paper? Using Outlook 6
J Force the 'From' account Using Outlook 1
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
George Simpson "Switch to HTML" in Outlook 2016 notes field Using Outlook 1
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
S Outlook 2013 doesn't download html messages Using Outlook 0
cabinet guy permanent response in html Using Outlook 1
C Signatures in HTML emails Using Outlook 5
I Outlook 2013 Appointments not in HTML Using Outlook.com accounts in Outlook 2
B Replies never HTML Using Outlook 2
Diane Poremsky Outlook crashes when viewing HTML Messages New Slipstick.com Articles 0
Diane Poremsky Create a New Message using an HTML File or Stationery New Slipstick.com Articles 0
V incorrect html signature printed Using Outlook 2
Z alter the timeout for how long outlook looks for a content-server on an HTML-email? Using Outlook 5
