Outlook .com group does not show up in Outlook for office 365 home
monicard
Outlook 2016 64 bit
Outlook.com (as MS Exchange)
I just created an outlook.com group for email and sharing a common calendar. Unfortunately the group does not show up in Office 365 home. Is the functionality more limited in office 365 or am I just not configured correctly? Thanks.
monicard
Outlook 2016 64 bit
these are the new Groups that just showed up in Outlook.com? The consumer version does not sync to desktop Outlook. I have no idea why they made that decision. :(
That is one of the dumbest decisions they have made. So that means you either use them and use outlook.com and then forget about desktop outlook. Cannot see the logic in their decision.
Agreed. I don't know if they will change the policy - it might depend on how much use Groups get. Personally, i don't see them getting a lot of use on the consumer side.
They also don't work properly with custom domains yet - I have it working on my custom domain because they did something on the backend to make it work when i asked about groups after seeing it pop up and complained that it wasn't working. <g>
M Outlook.com Group Contacts Not Showing in Outlook Using Outlook.com accounts in Outlook 2
T Outlook.com calendar as Group Calendar for Outlook 2013 users Using Outlook.com accounts in Outlook 2
C WARNING - DO NOT USE AN OUTLOOK.COM ADDRESS FOR GOOGLE ACCOUNT RECOVERY EMAIL Using Outlook 10
D Outlook.com premium finally dying... what do I do with my domain? Using Outlook.com accounts in Outlook 3
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
T upgrade from outlook.com to Outlook Using Outlook 2
T How do I upgrade from outlook.com to Outlook? Using Outlook 5
T I'm thinking about moving from outlook.com to the Outlook I have in my Office 365 Using Outlook 1
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
T Missing Folder in Outlook.com Using Outlook 3
dbjdbj Is it only me having a fun time with Outlook.com "beta" ? Using Outlook 3
I New Outlook.com Using Outlook 1
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
D Sharing outlook.com calendars in Outlook 2016 Using Outlook 1
M Can't send email in outlook.com Using Outlook 9
T BitDefender reporting outlook.com as 'insecure' Using Outlook 6
T Some of my folders in outlook.com appear to have vanished, thanks to v1803 Using Outlook 11
C Syncing on outlook.com Using Outlook 4
S Outlook.com birthdays show up 1 day late on iPhone contacts list Using Outlook.com accounts in Outlook 27
S Outlook.com cannot edit some contacts Using Outlook.com accounts in Outlook 5
B Outlook.com People Limits Using Outlook.com accounts in Outlook 11
M Outlook.com autocomplete list invaded by strange items Using Outlook.com accounts in Outlook 7
M Mailbox Size Outlook.com or Outlook 2011 Using Outlook 1
C Long List Of Outlook 2016/Outlook.com Bugs // Where To Report? Using Outlook 10
M How many days are items in Recover Deleted at Outlook.com ? Using Outlook.com accounts in Outlook 4
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
W Cant connect to outlook.com from outlook Using Outlook.com accounts in Outlook 2
J Outlook 2016 and Outlook.com Using Outlook.com accounts in Outlook 1
J Outlook.com with outlook 2016 Using Outlook.com accounts in Outlook 2
D Outlook.com in Outlook 2016 Trys & Fails to Send on Behalf of Itself Using Outlook.com accounts in Outlook 2
S Outlook.com Sync working, Sync to Android has issues Using Outlook.com accounts in Outlook 1
