Message search and edit, another way?
jrceloni
Outlook 2016 64 bit
While composing a reply, I want to do simple repetitive editing of the message body: e.g. when cursor is at the '<' an e-mail address, e.g. "Wig, Big <bigwig@contoso.com>", I want to hit a hotkey and strip the address (leaving "Wig, Big"; bonus if it moves the cursor to the next '<'). Long ago I did a little VBA in Word, Outlook, and Access but don't see an easy way to do this. (I don't even need to do a loop; in fact I don't want to since I don't necessarily want to strip all the <...> strings.)
I now have an AutoHotKey hotkey to do Del, Ctrl-Del, Del, then alt-o f d f space alt-f to find the next one, but it only works when the address inside the <> is really a link, since if it's just text, it'll just delete the first "word" of the address. A VBA solution could work more reliably and allow more flexibility...
This is from one i use in Word to remove 0 from leading dates, with the pattern changed to remove < address > and it tweaked to work in outlook. it may be a bit messy...
select the address - you actually only need to select the <address> part, but could just do a select all instead - the pattern looks for an email address inside <>
.Pattern = "(<(.*)@(.*)>)"
2818
Sub RemoveAddress()
Dim objItem As Object
Dim objInsp As Outlook.Inspector
' Add reference to Word library
' in VBA Editor, Tools, References
Dim objDoc As Word.Document
Dim objSel As Word.Selection
'On Error Resume Next
Dim SectionText As String
Dim RegEx As RegExp, Matches As Object, Match As Object
Dim i As Integer
Dim M1 As MatchCollection
Dim M As Match
Set RegEx = CreateObject("vbscript.regexp")
With RegEx
    .Global = True
    .MultiLine = False
'Reference the current Outlook item
Set objItem = Application.ActiveInspector.currentItem
If Not objItem Is Nothing Then
  If objItem.Class = olMail Then
    Set objInsp = objItem.GetInspector
' replace the With block with your code
With objSel
SelectionText = objSel.Text
  If RegEx.Test(SelectionText) Then
      Set M1 = RegEx.Execute(SelectionText)
For Each M In M1
 strFind = M.SubMatches(0)
  objSel.Find.ClearFormatting
  objSel.Find.Replacement.ClearFormatting
  With objSel.Find
    .Text = strFind
    .Replacement.Text = ""
    .Forward = True
    .Format = False
    .MatchCase = False
    .MatchWholeWord = False
    .MatchWildcards = False
    .MatchSoundsLike = False
    .MatchAllWordForms = False
  objSel.Find.Execute Replace:=wdReplaceAll
  Set MsgMatches = Nothing
  Set Match = Nothing
    Set RegEx = Nothing
    Set objItem = Nothing
    Set objWord = Nothing
    Set objSel = Nothing
    Set objInsp = Nothing
jrceloni
Outlook 2016 64 bit
Wow that was fast; thank you.
I had limited success and also see that I know much less than I thought. I did create a module and via Tools/Refs added the Word and RegExp libraries (Word alone didn't seem enough), then opened an Outlook mail item, manually selected a <email@addre.ss>, ran the sub via VB menu, and the <...> went away, but when I just put the cursor at or before the '<' or selected more or less text around the <...> or selected all, either it didn't work or generated an error. Then (optimistic it would eventually work) I navigated around looking for a place to assign the sub to a hotkey (as I would a macro in Word) and couldn't find it.
Since I'd like to understand enough to make it work, I'll shift my question to what resource(s) you recommend to an old programmer (1st languages were Fortran and 360 assembly language, made it through Basics and C's etc. but now do more with SQL...) to get a little better at VBA...
Thanks again.
fast is easy when i already had the macro. :)
that is because it's working on the selection -
Select a paragraph or the entire email and run it.
Outlook doesn't do shortcuts - you can add it a button for it to Quick access toolbar or to the ribbon.
B Search: Cannot find which Folder Contains a Message Using Outlook 3
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
H Using Outlook Rules to search for NewLines in message body Using Outlook 1
C Odd error message not found in Google search Using Outlook 1
A Outlook 2007 message search results loses focus Using Outlook 7
B MS Office 2010-calendar search feature; whenever I invoke this, I get an error message and the s/w closes MS Office and restart it Using Outlook 2
R Reading email problems. Bing search box appears in the message area Using Outlook 1
Y A "Cannot open this item" error message occurs when you try to open a message from the search result Using Outlook 9
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
C Why won't Title display in message list? Using Outlook 1
icacream content in this message could not be downloaded.... Using Outlook 2
R Warn before sending message Outlook VBA and Custom Forms 4
M Message list font changed after update Using Outlook 2
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
evdbogaard Reply with only last message cited Using Outlook 1
T O365 and Office Message Encryption Exchange Server Administration 2
D Outlook Message Window Changes Size and Position Using Outlook 1
P Message List Font Changed Using Outlook 6
D Paste Excel table into Outlook message Outlook VBA and Custom Forms 6
W Message Text Using Outlook 1
J Searching message folder in Outlook 2016 Using Outlook 5
