Outlook macro to automate search and forward process
mkunk1
is this possible?
Is there a way to use a macro that will search an inbox for a part of a subject line from an email then forward the search results to another email?
Example: Macro is triggered, for each COMPLETE email in the inbox, subject line of the email is “This is the subject COMPLETE”, I want outlook to search my inbox for ”subject”, any emails with “subject” in the subject line get forwarded to a different email then move on to the next email with COMPLETE in it and repeat.
To clarify, the macro should always search the item (combination of letters and numbers, always 15 characters long) to the left of COMPLETE.
Also, it would not need to be triggered once the COMPLETE email comes into the inbox (ok to be triggered manually) but would need to treat each complete email as a separate “job” to repeat the search and forward for each email with complete in the subject.
Yeah, it would be possible. If there are not many messages in the folder, you can just loop through the folder, but if there are a lot, you'll want to use a filter 9Find or Restrict function) then loop the results to send.
I'll see if i can find some code that comes close to what you want.
mkunk1
Thank you Diane. I have tried googling and searching for a similar code, is there anywhere in particular you would recommend looking?
i have this macro which is close - then we just need to loop the results and send. I'm pretty sure i have something to loop - sending is easy.
this example uses a slower method- checking for the value then doing whatever - it would be slow if you had much mail.
mkunk1
Would this find the related messages by subject? The only issue is sometimes a new email is sent for the same topic instead of a reply and as such the subject line may not be identical across all the emails.
mkunk1
Would this find the related messages by a keyword(s) in the subject? The only issue is sometimes a new email is sent for the same topic instead of a reply and as such the subject line may not be identical across all the emails.
Edited. "keyword(s) in the subject"
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
P Macro to attach a file in a shared Outlook draft folder Outlook VBA and Custom Forms 2
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
L Outlook 2007 - Macro Re Search Using Outlook 16
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
A newb outlook macro help Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import Contacts and vCards into Outlook Using Outlook 0
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
S Macro in an excel for outlook. Outlook VBA and Custom Forms 2
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
S Outlook Macro Reply to a message Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import vCards into Outlook Using Outlook 0
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
P Outlook Macro sends information to Excel Using Outlook 1
B Looking for Outlook 2013 update for Send Drafts Macro Using Outlook 4
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
S Macro for Reply All in 2013 Outlook Outlook VBA and Custom Forms 10
L Outlook 2007 Macro Save Contact Using Outlook 10
Aussie Looking for Outlook macro to Copy Recipient Names into Email Body Outlook VBA and Custom Forms 3
H Outlook Macro Using Outlook 1
L Outlook 2007 Macro Reply to E-mail Using Outlook 16
