Attachment saving and tracking - PLEASE help!
LTampkins
many years ago a developer working for me, created a VBA module that did the following when saving attachments:
  • recorded the file path you saved it to
  • appended the email to say: "the attachment <filename> was saved to <file path> on <date>"
  • and then removed the attachment from the email.7
I cannot figure out how he did it, or if it is even still possible. I have seen some similar examples but these do things like bulk strip out attachments into a pre-determined folder, or just remove the attachments. None of them do exactly what i need. can anyone help?:mad:
i have several code samples here:
LTampkins
yeah I have seen these. in fact this is what i referenced in my post. it saves to a specific folder (OLAttachements) - I want one that simply captures the location i CHOOSE to save the file too as a string and append it to the mail..
That's not hard to change. get the browse for folder function (link below) - and change this line
strFolderpath = strFolderpath & "OLAttachments"
to this:
strFolderpath = BrowseForFolder("C:\Users\username\documents\")
(or whatever you are using as the base path)
change this line to add the last slash:
strFile = strFolderpath & strFile
like this:
strFile = strFolderpath & "\" & strFile
nothing really to code - add the function after the End sub and change two lines.
  • save-attachments.txt
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
K Copy Subject Line When Saving Attachment Outlook VBA and Custom Forms 2
M Saving an attachment - outbox and sent mail conflicts Outlook VBA and Custom Forms 10
N Saving attachment from shared mailbox Outlook VBA and Custom Forms 1
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
B Outlook 2010 Opening Mail Attachment Using Outlook 2
A Warning When Opening attachment Using Outlook 7
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
D Autosave Attachment and Rename Outlook VBA and Custom Forms 1
N Macro for attachment saved and combine Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
Commodore Attachment icon when there is no attachment Using Outlook 3
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
M Search for attachment filename Using Outlook 0
E Open olNoteItem Attachment Outlook VBA and Custom Forms 6
Vijay Reply all by attachment name Using Outlook 10
Michael R Belleville Making an Attachment Name the Message Subject Using Outlook 2
N Paste content to Excel when .txt file (attachment) is opened Outlook VBA and Custom Forms 1
P Outlook Randomly Not attaching (attachment file) Using Outlook 0
S VBA to search a keyword in attachment and move to a folder Outlook VBA and Custom Forms 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
O Maker Checker - Colleague to authorise attachment Using Outlook 0
C Outlook Attachment List in Reply Header Using Outlook 3
Randy Redekopp Outlook 2016 attachment content search Outlook VBA and Custom Forms 2
A OL16 C2R attachment preview fails Using Outlook 8
R Print email message and attachment in order Outlook VBA and Custom Forms 2
RalphG101 No indication of attachment, when selecting file, send to outlook. Using Outlook 0
A "untitled attachment" if file name contains eg. special character Using Outlook 1
Mark Foley Emailing attachment from Word/Excel sends attachment but no message body Using Outlook 0
peacepanda How to save attachment looking at the attachment name Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachment Names to Message Before Sending New Slipstick.com Articles 0
