Search for incoming e-mails for a specified time range
Tomohawk
I need to create a report of the number of incoming e-mails for a specific date/time range and by category. Each e-mail is categorized, but would also need to report those with blank category, so best to report by all categories. The report would take the form of a list of those e-mails, ordered by category. I can select the range for each category and get the count that way.
Is it possible to create a search, which prompts for start date and time and end date and time and that can be saved and reused for this purpose.
You can do instant search, which is set up using a macro - or you can use a view with the fields visible that you need and copy & paste into Excel and filter there.
This macro has some examples - you'll replace the search string with the one you need and use input boxes to get the dates you want to use
For example, for received:>11/1/2019 <11/11/2019 category:="Anniversary"
strStart = InputBox("Enter Start date", "Enter date in mm/dd/yy format")
strEnd = InputBox("Enter End date", "Enter date in mm/dd/yy format")
strCategory = InputBox("Enter Category", "Enter category name")
txtSearch = " received:>" & strStart & " <" & strEnd & "category:=" & chr(34) & strCategory & chr(34)
L New Location for the Search Bar Using Outlook 6
King Mustard Sort search groups by amount of items? Using Outlook 1
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
W Search Incomplete Outlook 2016 Using Outlook 5
R outlook address book search broken Using Outlook 2
R What's supposed to appear when just clicking into the search field? Using Outlook 7
B Instant search with special characters Using Outlook 1
A Search folder refresh Outlook VBA and Custom Forms 3
M email search not working Using Outlook 1
F Search folder for tasks in all task folders Using Outlook 1
B Search: Cannot find which Folder Contains a Message Using Outlook 3
M how to speed up search of shared contacts Using Outlook 0
C Search with Google Macro? Outlook VBA and Custom Forms 4
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
E Outlook 2016 Inbox search bug Using Outlook 1
P Outlook search is not working at all for Calendar & Tasks Using Outlook 7
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
M new search just... sucks Using Outlook 4
B Search function in Office 365 has stopped working Using Outlook 3
J Marco in search of text in subject line Using Outlook 8
T Delete Emails from search results Outlook VBA and Custom Forms 1
P Can't search Archive'd Tasks Using Outlook 0
J Search by catagory Using Outlook 4
skyfox VBA to search email subject field for a certain string Outlook VBA and Custom Forms 3
