How to distinguish whether mail is incoming or outgoing?
oliv-
I usually use this test to find out if the email is incoming or outgoing.
But now i see that Emails sent via the Outlook Android Application return .ReceivedByName = "My name"
and Emails sent by TypeApp (Android) return a Internet Message Header !
    Const PR_TRANSPORT_MESSAGE_HEADERS = "http://schemas.microsoft.com/mapi/proptag/0x007D001E"
    Set objmail = ActiveInspector.CurrentItem
    Set olkPA = objmail.propertyAccessor
    GetInetHeaders = olkPA.GetProperty(PR_TRANSPORT_MESSAGE_HEADERS)
    If objmail.Sent = True And objmail.ReceivedByName = "" Then
        sens = "out"
    ElseIf objmail.Sent = True And GetInetHeaders= "" Then
        sens = "out"
    ElseIf objmail.Sent = True And objmail.ReceivedByName <> "" Then
        sens = "in"
        sens = "Draft"
is there a better way ?
Lewis-H
Outlook 2016 64 bit
This is how I check mail type and it works even if mail is moved to any folder. This solution uses PROPERTY ACCESSOR which is available in outlook. Below is the code
string PR_MAIL_HEADER_TAG = "schemas.microsoft.com/mapi/proptag/0x007D001E";
Outlook.PropertyAccessor oPropAccessor = mItemProp.PropertyAccessor;
string strHeader = (string)oPropAccessor.GetProperty(PR_MAIL_HEADER_TAG);
if (strHeader == "")
// MAIL IS OF TYPE SENTBOX
else
// MAIL IS OF TYPE INBOX
Lewis
oliv-
Thank you Lewis, but i still use this property.
and sometimes for emails that i send with my smartphone (Typeapp )there is headers.
M Filter rules to distinguish To and CC fields Outlook VBA and Custom Forms 1
glnz O365 - How to control whether my From name shows as "Dicky". Using Outlook 1
S exchange power shell whether run on scheduler Exchange Server Administration 4
M Auto-reply with macro whether logged in to outlook or not Outlook VBA and Custom Forms 2
D Check whether mail item is proper for sending or not Outlook VBA and Custom Forms 5
H out to check whether outlook configured or not Outlook VBA and Custom Forms 1
Q Re: Detecting whether a toolbar is and should be shown Outlook VBA and Custom Forms 5
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
MrMayor SENT mail not reloading to top?? Using Outlook 4
ThinkToday Calculate reply time of outlook mail Using Outlook 1
B Outlook 2010 Opening Mail Attachment Using Outlook 2
D Mail in Sent Items Gone Using Outlook 12
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
S Outlook not receiving mail Using Outlook 1
W Receiving mail for account that has been deleted Using Outlook 2
O How to prevent CC from showing when creating a new mail? Using Outlook 1
I Junk Mail and PersonMetadata Using Outlook 2
T 3 months of archived e-mail is missing Using Outlook 1
B Outlook - Mail from safe senders list being sent to Spam Folder Using Outlook 0
G Detect Google Drive and OneDrive links in incoming mail Outlook VBA and Custom Forms 3
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
D after delete mail, open the next one Outlook VBA and Custom Forms 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
B Clear Offline Items (Mail Folder) via VBA Outlook VBA and Custom Forms 1
M Moving mail to another folder is much slower than before (Office365) Using Outlook 0
M Sent mail not showing in my sent folder Using Outlook 9
CWM030 Connected accounts mail moved to trash? Exchange Server Administration 16
