Expand VBA Permanent Delete Code
Post number 2 has been selected as the best answer.
RayB
I am using Outlook 2007 and really understand Excel VB, however, my Outlook VB capability is as a novice.
I have a VBA macro that moves email messages to a folder called rb Auto Deletes positioned as shown below:
After hours of searching and trying different approaches I have written this code which will permanently delete messages without going through the Outbox:
Sub AutoPermDelete()
' Usage: program mimics the entry of Shift + Delete to permanently delete an email
' How to use: select the mail item, execute this macro
Dim myOlApp As Outlook.Application
Dim myNameSpace As Outlook.NameSpace
Dim Sel As Selection
Set myOlApp = Outlook.Application
Set myNameSpace = myOlApp.GetNamespace("MAPI")
Set Sel = Application.ActiveExplorer.Selection
SendKeys ("+{DELETE}")
SendKeys ("{ENTER}")
The code works perfectly but I have to select each email. So what I would like to have help with expanding the code to do the following:
1. 'Look' at the rb Auto Deletes folder.
2. Determine which messages are older than 1 calendar year from the current date and permanently delete them using my code.
I am totally lost as to how to make this happen and all my attempts have not worked so I am asking for help.
Merry Christmas and Thanks in Advance for your help!
oliv-
try this
Function Nettoyage_Inbox()
' Procedure : Nettoyage_Inbox
' Author    : OCTU
' Date      : 11/01/2015
' Purpose   : permanently delete emails
    Dim Dossier As Folder
    Dim NS As NameSpace
    Set NS = application.session
    Set Dossier = NS.GetDefaultFolder(olFolderInbox).Parent.Folders("rb Auto deletes")
dim myItems
 madate = DateAdd("yyyy", -1, Date)
    Set myItems = Dossier.items.Restrict("[LastModificationTime] < '" & madate & "'")
    While myItems.count > 0
       myItems.Remove 1
        'Dossier.Items(1).Delete 'garde historique Exchange
    Wend
End Function
Lewis-H
Outlook 2016 64 bit
To delete a row using VBA, use a statement with the following structure:
1Worksheets.Rows(Row#).Delete
  1. Item: Worksheets.
    • VBA Construct: Workbook.Worksheets property.
    • Description: Returns a Worksheet object representing the worksheet you work with.
  2. Item: Rows(Row#).
    • VBA Construct: Worksheet.Rows property.
    • Description: Returns a Range object representing row number Row# of the worksheet returned by item #1 above.
      If you explicitly declare a variable to represent Row#, use the Long data type.
  3. Item: Delete.
    • VBA Construct: Range.Delete method.
    • Description: Deletes the Range object returned by item #2 above.
Macro Example
The following macro deletes row 6 of the worksheet named “Delete row”.
view source
print?
1Sub deleteRow()
2 Worksheets("Delete row").Rows(6).Delete
3
4End Sub
Hope this is helpful!
Regards,
Lewis
oliv-
Lewis, it's not EXCEL but OUTLOOK
RayB
try this
' Author    : OCTU
' Date      : 11/01/2015
    Dim NS As NameSpace
dim myItems
       myItems.Remove 1
    Wend
End Function
Thank you so much it works perfectly!
RayB
One other question is do you know a way to add this function to run from a button on the a toolbar? From what I have read, the classical way to add a button to control a macro will not work because Functions do not show up in the Macro list.
Again, Merry Christmas and Thanks in Advance for your help!
It should work if you change it to a sub or use a simple macro to call it:
sub Deletemail()
Nettoyage_Inbox
end sub
I have a macro here that empties all mail in folder (it may not work in 2007 though)
This shows how to work with selected items:
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
R The way expand/collapse folders is actually meant to work? Using Outlook 2
K cannot expand the folder outlook 2007 pst Using Outlook 1
S Automatically expand a folder when new mail arrives Using Outlook 7
C Unable to expand ANY folders after adding another gmail account. 2007. Using Outlook 4
N auto expand all folders and subfolders in the inbox Using Outlook 3
R How do I expand all distribution lists in the To: section? Using Outlook 4
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
J Expand Distribution List on Send Outlook VBA and Custom Forms 1
