Outlook 2016 will not move emails in search results
Vincenzo
My sister-in-law does a search in Outlook and tries to move an email from the search results into a folder. But instead of moving it, it is only copying it.
Any ideas how to fix this?
Vincenzo
OK thanks so much for that tip, it led me right to the solution.
Yes you were right, the email WAS being moved.
IT turns out though that the folder she moves the emails into are a subfolder under the same email account, so the search is, correctly, still showing it.
So the fix is that she has to remember to change the search parameter from Current Mailbox, to Current Folder, then it does not show up after it has been moved.
Jennifer Murphy
Outlook 2016 64 bit
Are you sure its copying it and is not just appears to be copied because the search didn't properly refresh? They definitely should move if she is dragging or using the move to folder command.
Thank you, thank you, thank you!!! I was just wrestling this this exact problem.
Can I change the default search area to "Current folder"? IMHO, "Current mailbox" is a stupid default setting. I just wasted half an hour trying to figure out why Outlook was copying, not moving, emails.
Sapina
Outlook 2016 64 bit
wow I was also making this same rookie mistake and then I followed your advice on this forum and your tip actually worked, so I joined this forum specially to Thank you.
Cdub27 Move Outlook 2016 Contacts to Other Folders - Extremely Slow !! Using Outlook 6
G Favorites panel entries move around after restarting Outlook 2016 Using Outlook 1
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
GregS Outlook 2016 Outlook 2016 stalls Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
K Outlook 2016 Using Outlook 0
W Search Incomplete Outlook 2016 Using Outlook 5
A Outlook 2016 not synching Using Outlook 4
B The Outlook 2016 Profile that isn't always there Using Outlook 2
