Outlook 2013 "Item could not be moved - still an issue for Outlook 2013
PhilBurton
Outlook 2013 64 bit
I have run into this bug only in the past year or two, even though I have been using Outlook 2013 since, oh, about 2013. There is a closed thread on this topic in this very forum. Item cannot be saved because it was modified by another user or window
In the most recent case, even after selecting another message, I still can't move, or even copy, a particular message. I just did a "check for new mail" sync, and that didn't solve the problem.
Phil Burton
S Can't move the items. The item could not be moved. It was either already moved or deleted, or access Using Outlook 3
S Error 0x80040600 + Cannot move the items. The item cannot be moved . . . Using Outlook 9
S Command Button_Click action on Item/Reminder Outlook VBA and Custom Forms 3
T Pictures degrade each time an Outlook item is edited and re-saved Using Outlook 1
GregS Many Sent Item folders Using Outlook 3
B Select / activate first email item in the searched query Using Outlook 1
N "Discussion" item Using Outlook 3
Peter H Williams How to Move Mail item after processing Outlook VBA and Custom Forms 5
M Shortcut to another outlook item Using Outlook 0
Cdub27 Your changes to this item couldn't be saved because Server Denied Operation (HTTP 403 Forbidden) Using Outlook 1
G Outlook item link Using Outlook 0
D Save Sent Item to Using Outlook 0
Jeanne Goodman Delete Calendar Item Bypassing Deleted Items folder Outlook VBA and Custom Forms 2
Diane Poremsky Display the Created Date field of any Outlook item New Slipstick.com Articles 0
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item New Slipstick.com Articles 0
Z Item.Recipients for Task Assignment on Send Outlook VBA and Custom Forms 10
J "This item has been changed still want to delete it" message Using Outlook 3
oliv- HIDE ITEM Outlook VBA and Custom Forms 3
D Shared Mailbox with mail item marked as "private" Using Outlook 0
Diane Poremsky Change Item Count on All Folders in a Data File New Slipstick.com Articles 0
M Recurring icon for custom form task item Outlook VBA and Custom Forms 6
williamlambton Reinstate "Open" button on mail item right-click context menu. Outlook Wishlist 2
V Locate item Account Outlook VBA and Custom Forms 7
JohnP Shared Mailboxes "Save Sent Item" Using Outlook 2
D After Moving or Deleting Open Item - Meeting Requests Using Outlook 4
S Item Add Event fires intermittently Outlook VBA and Custom Forms 3
R How do I 'Save Copy of Sent Item to Folder' for a Shared Mailbox Outlook VBA and Custom Forms 9
P Item cannot be saved because it was modified by another user or window Using Outlook 8
B Extract Dates for Appointment Item in Body of email Outlook VBA and Custom Forms 10
Rory Campion Not getting a warning when a shared calendar item has been updated by someone else Using Outlook 2
N Saving .msg as sent item on send Outlook VBA and Custom Forms 1
