.pst archive from work will not open/import on Microsoft 365
ncwildbu
Hi All,
I used the archive/backup function on my work email (Microsoft Exchange server) to save all my emails to an external hard drive.
It appeared to work. It looked like things were being processed or archived to my external hard drive. When I look at the folder properties on the hard drive there is data because it tells me how much MB or GB there is.
However, when I follow the procedure to import the .pst files into my personal Outlook account it does not take and I have tried everything. Then I recently came across this:
“Archive and AutoArchive might not be available if your mail profile connects to an Exchange Server. It's also possible that your organization has a mail retention policy that overrides AutoArchive. Check with your system administrator for more information.”
Archive older items automatically
Does anyone know of a way to either check if this is true or how to recover the emails that I cannot import into my Outlook?
semnaitik Archive PST is not empty but can't see old emails Using Outlook 2
B Relocating archive.pst file Using Outlook 6
D I can’t access my archive.pst Files Using Outlook 2
O Importing pst, archive pst and address not working Using Outlook 17
D Add data in archive.pst to outlook.pst Using Outlook 4
H Opening .PST archive files in Outlook 2007 Using Outlook 10
U "archive.pst cannot be opened" when archiving Using Outlook 4
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S What's in a PST file? Using Outlook 1
N pst files are recreating automaticaly and cannot be deleted Using Outlook 5
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
N Two .pst files on one computer both with contacts? Using Outlook 9
DariTrevino MIcrosoft Outlook PST file cannot repair Using Outlook 1
E Exporting email (.pst) Using Outlook 8
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
E How to transform .OST in .PST ? Using Outlook 1
O Any decent tool to compare .pst files? Using Outlook 2
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
I Flagged emails in pst file corrupt to do list Using Outlook 12
O How to display number of items per .pst file Using Outlook 7
