How to open a specific link automatically with outlook 2016
Alipio
Outlook 2016 64 bit
Hi, i´m a novice in this subject and I hope Diane can help me.
I have a code to open automaticly an email from a defined sender.
I´m having problems to join the code to click in a certain link. May I have your help please?
What I need is open the email when he arrives and click in the link in a defined text
I have this:
Public WithEvents objInbox As Outlook.Folder
Public WithEvents objInboxItems As Outlook.Items
Set objInbox = Outlook.Application.Session.GetDefaultFolder(olFolderInbox)
Set objInboxItems = objInbox.Items
'Occurs when incoming emails arrive in Inbox
Private Sub objInboxItems_ItemAdd(ByVal Item As Object)
Dim strSenders As String
Dim varSenders As Variant
Dim i As Long
If TypeOf Item Is MailItem Then
Set objMail = Item
'Change the specific persons
strSenders = "Alijos@gmail.com"
varSenders = Split(strSenders, ";")
'Open the emails from specific persons
For i = 0 To UBound(varSenders)
If objMail.SenderEmailAddress = varSenders(i) Then
objMail.Display
Exit For
And what I need is to click automaticly in a link with the text "Fich a Subm Contab"
wayting for your help
Lewis-H
Outlook 2016 64 bit
Open hyperlink without holding Ctrl in Outlook
  1. On the File tab, click the Options button:
  2. In the Outlook Options dialog box, on the Mail tab, click the Editor Options button:
  3. In the Editor Options dialog box, on the Advanced tab, under Editing options uncheck Use CTRL+Click to follow hyperlink:
  4. Click OK.
Alipio
Outlook 2016 64 bit
  4. Click OK.
Hi Lewis-H, thank you for your time. and what should I expect with this procedure?
You need to merge it with this code -
I think this will work - the pattern might need tweaked though.
.Pattern = "Fich a Subm Contab <(.*)>"
Copy one of the messages to the junk email folder and see how it looks in plain text - that is what you need the pattern to look like.
  • openlink macro.txt
Alipio
Outlook 2016 64 bit
Diana, I don´t have word enough to thank you.... it works great.... you are really a GEM... but a big one.
amitkumarvinay
Outlook 2016 64 bit
I do not have the access to update the registry to enable the "Run a script" option in Rules wizard. What are the alternate options to make this happen ? I want to be able to click on a link from a particular sender with a particular subject of the email everytime that emails comes to my inbox. Kindly please help
A How to open a specific link automatically with outlook Outlook VBA and Custom Forms 13
L Macro to Open a Specific Word Document - Outlook 2007 Using Outlook 17
C Want to Create Shortcut to Open Specific Calendars at the Same Time Using Outlook 2
X open specific e-mail messages in outlook 2007 c# Outlook VBA and Custom Forms 1
K Embedded photos no longer open with Photos or Photo Viewer Using Outlook 7
witzker Open Contact missing in Outlook 2019 Using Outlook 2
sahameed82 SharePoint calendar directly open in Outlook Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
C Can't Open Outlook 365 Using Outlook 0
D after delete mail, open the next one Outlook VBA and Custom Forms 0
M outlook won't open! Using Outlook 1
M other user's mailbox won't open, forms disappeared Using Outlook 42
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
S Reminder Dialog Open Button Using Outlook 2
N open the hyperlink in Outlook directly instead of browser Using Outlook 1
A open Outlook with multiple windows. Using Outlook 0
K open calendar from address book Outlook VBA and Custom Forms 1
T Double clik behavior on agenda open a new meeting request Using Outlook 1
E Open olNoteItem Attachment Outlook VBA and Custom Forms 6
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item New Slipstick.com Articles 0
Diane Poremsky Rules & Alerts Dialog Won't Open New Slipstick.com Articles 1
Diane Poremsky Outlook 2013: Control Panel Mail Won't Open New Slipstick.com Articles 0
O Cannot open or save calendar items Using Outlook 0
Diane Poremsky Outlook Links Won't Open In Windows 10 New Slipstick.com Articles 1
C scanpst.exe will not open Using Outlook 0
B ...administrator has limited the number of items you can open simultaneously Outlook VBA and Custom Forms 7
Diane Poremsky Open a Webpage When a Task Reminder Fires New Slipstick.com Articles 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
