Outlook 2010 Problem with OutLook 2010 32 bit, after Windows Auto Update
Mac
In W10: I'm using: MS Pro Plus 2010
And the following problem with Outlook, occurred after an Automatic Windows Update.
After opening Outlook, if you click on an email-title,
(in the top-right section that list all the emails that you've received)
and then delete it, then it usually deletes OK, but then...
...3 Popups Appear...
1: File Download: Getting File Info / Estimated time left, etc (with a stationary barometer)
2: File Download: Do you want to save this file
(NB: this file name changes each time)
Type: FireFox HTML Document 6.40 KB
From: C:\Users\ted\AppData\Local\Microsoft\Windo...
3: The required file MSHTML.dll cannot be found in your path. Install Microsoft Outlook again
Closing Popup 2: Closes popup 1
and may let you continue deleting other emails, but the same popups will keep appearing, and at some point, it wont display the contents of an email in the bottom-right-window
Closing Popup 3:
Closes Outlook, but it may (or may not) automatically re-load.
Either way, the problem occurs each time you open Outlook.
Q: So is the only solution to re-install Outlook ?
If so:
Do I need to remove Outlook first ?
And can I remove just Outlook, without having to remove MS Pro Plus 2010 ?
And will removing & re-installing Outlook, remove any of my 3-email-accounts, setup preference, address-book, saved emails, etc, etc.
NB 1: Outlook is not listed in the control-panel, only: MS Pro Plus 2010
NB 2: My system clock was also an hour late, even though it's set to get the correct time from the net, but this corrected itself after a few days.
Many thanks
Vincenzo
You can try a repair on Office. Do that from Control Panel/Programs and Features/Office/Change
Mac
Thanks for your reply.
Unfortunately, the [Repair] option does not display, when I select MS_Office.
Only: Organise, Uninstall, Change.
Vincenzo
It is under Change. Try the Quick Repair first, then if no good still, then the other.
P problem with set up group by conversation in outlook 2010 Using Outlook 3
D Icloud Outlook 2010 Task/Reminder Search Problem Using Outlook 1
K Outlook 2010 - sending pdf about 8 MB problem Using Outlook 2
H Downloading Outlook 2010 from Volume Licensing Centre problem Using Outlook 1
M Outlook 2010 Custom Form Problem Using Outlook 1
A i have problem with my outlook 2010 pop account Using Outlook 2
B outlook 2010 problem Using Outlook 1
L Outlook Contacts 2010 problem with Notes section configuration Using Outlook 22
J Problem using drag and drop to attach an html email in Outlook 2010 Using Outlook 18
X Problem Transferring Subset of Outlook 2013 Contacts to iPad/iPhone Using Outlook 5
K Outlook(hotmail)Yahoo problem Using Outlook 6
N Outlook 2013 and Surface RT synchronisation problem Using Outlook 3
F Outlook group by conversation problem Using Outlook 1
J it goes like outlook has stopped working, a problem caused the program to stop working correctly, wi Using Outlook 2
T Problem With Mail Setup IN Outlook 2013 Using Outlook 2
C Outlook problem Using Outlook 9
L Outlook DST (Daylight Saving Time) problem Using Outlook 0
D Problem with MS mail and outlook 2007 OS Windows 8 Using Outlook 1
M Outlook synchronisation problem (Error : 80041003) Using Outlook 0
S Problem syncing mail from a POP3 account in Outlook 2013 to iphone 5 Using Outlook 1
A Problem sync group goole calendar with outlook 2001 Using Outlook 0
J outlook problem it allow to book meeting room at the same day & time Using Outlook 0
B Outlook network password problem. Using Outlook 0
L Problem with Outlook 2007 with windows 7 Using Outlook 0
V New problem, .oft extentions in Outlook 2013 Using Outlook 5
W Outlook Stationary Font Formating Problem Using Outlook 7
J My Headset problem when Dialing Out from Outlook Contacts Using Outlook 1
C Problem with Outlook truncating images Using Outlook 6
W New Problem using Outlook over network Using Outlook 1
