Export-Import .pst file problems
MattInLA
I upgraded to Win-10 / Office 2010 on a new machine, and am moving over 1500 contact records critical data for my business from Win-7 outlook 2007. There are 3 user defined fields and they do not appear in the exported file, I googled this issue and it seems outlook does not export UDF's. So, I did some testing, inserted a NAME field into my existing CONTACTS records folder). You can rename this to whatever you want and I did, and this interestingly, now shows up as a UDF field which does not export either. SO, I did even more testing, deleted that column I re-selected the NAME column, did not change the name of the NAME column , inserted that, added some data, exported and THAT field does not show up either, so WHAT exactly is going on? I viewed my .PST file directly with a .PST viewer, EXTREMELY HANDY for t his. WHAT are the rules here for exporting fields in Contacts folder? This is a big deal, I have a large contacts file with column data I CANNOT MIGRATE / EXPORT. Big problem.
UDFs do not export. Or import.
You cab use the user1 - user4 fields for the data (use a macro to move the data to and from those fields) or use a macro to export all fields. But... you don't need to. If you have the data in a pst in 2007, copy the pst to the new computer. Or export the contacts to a pst. Moving an existing pst to the new computer has a number of advantages, including you'll keep views, rules, categories, and custom forms
Why not? Moving the contacts as outlook contacts is the most efficient method and will preserve the fields and their values.
J Opening/Archiving/Import/Export PST files Using Outlook 4
R Flagged for Follow Up Search folder MIA after PST export/import Using Outlook 1
Sarge USMC Cannot import/export Outlook 13 Using Outlook 6
L Outlook 2007 Codes Export and Import Using Outlook 9
L Outlook 2007 Toolbar Export and Import Using Outlook 7
T Distribution List - Export/Import Using Outlook 4
K outlook 2007 Export/Import Distribution lists Using Outlook 1
L Import/Export BCM (Business Contact Manager) 1
B BCM shuts down everytime I try to import/export or check for error BCM (Business Contact Manager) 10
S Business Data Import and Export Load Error Cannot Map BCM (Business Contact Manager) 1
K Export Folder to PST Outlook VBA and Custom Forms 2
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S How to export urls from email to excel and check the status of the url ? New Slipstick.com Articles 6
C How to export Outlook data to csv? Using Outlook 0
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
avant-guvnor Export Calendar, Birthdays and Holidays Outlook VBA and Custom Forms 0
Diane Poremsky Export (Save) Outlook Contact photos New Slipstick.com Articles 0
A How to export one email data to excel Using Outlook 1
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
E Exchanger service export detection Exchange Server Administration 1
R Correct a wrong csv export file from WLM 2012 Using Outlook 0
H How to export *all* fields from Outlook Using Outlook 2
K Export Organizational Forms Library Exchange Server Administration 1
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
A export free / busy from exchange Exchange Server Administration 0
C Export to excel missing items, but a larger total? BCM (Business Contact Manager) 6
M Outlook 2013/365 won't export 99% of my contacts to csv Using Outlook 2
T Outlook 2007 Export tasks to Excel Using Outlook 2
H Select one of Contact-Mailadesses to Export > Excel or Winword Outlook VBA and Custom Forms 2
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
Jennifer Murphy Can I export individual emails? Using Outlook 1
R Export Address Book VBA Using Outlook 0
W How to export additional fields in contacts Using Outlook 1
R Recover/export rules from a backup .PST Using Outlook 2
J Formatting Contacts to Export for iPhone Using Outlook 0
