Forward a email with modified body Automatically.
OskarKjellman
Outlook 2019 32-bit
First time poster here, i took some time to read what the forum has to offer but i still have some questions
Description of the issue:
What i am trying to achieve is that when ever i receive a email with the Subject "XXXX" from the sender "XXXX" it will look in the body for a specific sentence, lets say "error123:" and it will have a description "this fail because of issues". This email contains a lot of information and everything should be striped except that error message. This error message could appear more then once in the body for example "error124" and "error125" as well or it could not appear at all and just be a simple email with lots of information. Once i verify that the email in fact does include this error message i want to forward only the error code plus the error message to a different email address and for simplicity it can be the same subject.
Points of concern:
  • I have been reading that you can add button(Macros) that can make this for you and it can be run when outlook it self is open, but is it possible to run this at night when i do not have outlook open?
  • This emails are coming to a mailing box and not my direct email does that have any impact on how i set this up?
Thx in advance.
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
D How to forward each email x minutes after it arrives in inbox and hasn't been moved or deleted? Using Outlook 1
W Macro to forward email Outlook VBA and Custom Forms 2
mikecox Forward email to another address; not with Rules Using Outlook 3
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
D forward email with attachment using .oft Using Outlook 3
R Auto-create receipt from email and forward to payer Using Outlook 3
C Unable to forward email with URL Using Outlook 2
M rule to change subject, pull email addresses from body, and forward with templ Using Outlook 14
A Outlook 2010 - Want to Have All Email Reply Forward as Rich Test Using Outlook 7
P email arrows - respond and forward Using Outlook 1
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
M Forward email as insert from button Outlook VBA and Custom Forms 1
J Rule to Forward email but delay delivery 10 minutes Outlook VBA and Custom Forms 2
S forward email Outlook VBA and Custom Forms 1
C UDFs Reply vs Forward Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
D Forward message to address from subject Outlook VBA and Custom Forms 1
J How to change From then forward message Outlook VBA and Custom Forms 1
S Reply & Forward Date in original message incorrect Using Outlook 2
Diane Poremsky Forward Messages that were not Replied To New Slipstick.com Articles 0
