Set objApp = Application Not Working in O365-32bit
bmtjedi
Outlook 2019 32-bit
Switched to O365 32-bit today and a macro that has worked since Outlook 2007 is no longer working. Any ideas why "Set objApp = Application" doesn't work? Error is Object Library feature not supported. This macro puts the conference info in the Location line for Skype meetings (which used to be OCS a long time ago - still works with Skype):
Sub OCS_Appointment_Location()
Dim objApp As New Outlook.Application
Dim objMsg As Object
Dim strBody As String
Dim strConfID As String
Set objMsg = Application.ActiveInspector.CurrentItem
strBody = objMsg.Body
strConfID = FindConferenceID(strBody)
objMsg.Location = objMsg.Location & ": 877-848-XXXX, " & strConfID & "#"
Set objApp = Nothing
Set objMsg = Nothing
Function FindConferenceID(strText As String) As String
Dim i As Long, J As Long, strTest1 As String, strTest2 As String
Dim strChar As String, strConfID As String
For i = 1 To Len(strText)
strTest1 = Mid(strText, i, 14)
If strTest1 = "Conference ID:" Then
For J = 15 To 30
strChar = Mid(strText, i + J, 1)
If Asc(strChar) <> 13 Then
strConfID = strConfID & strChar
FindConferenceID = strConfID
Exit Function
Next J
Next i
End Function
Thanks for any suggestions.
bmtjedi
Outlook 2019 32-bit
In case anyone is interested, I solved this problem. Remarking out the Set ObjApp line removes the error. Apparently, the Application object doesn't need to be set in Outlook 365 VBA.
F how do i set a reminder in onenote 2010 Using Outlook 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
O Set columns for all (sub)folders Using Outlook 8
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
F Set (flagged) reminder for next business day Using Outlook 4
L how to set downloaded cached emails Using Outlook 5
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge New Slipstick.com Articles 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
M Exchange 2013 On premise set MessageRateLimit for User has no effect. Exchange Server Administration 0
A Block user to send emails to specific set of email ids Using Outlook 1
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
Diane Poremsky Exchange account set-up missing in Outlook 2016 New Slipstick.com Articles 0
M To set the storage folder for an outgoing Outlook message Outlook VBA and Custom Forms 8
E Meeting reminders are set for the recipient Exchange Server Administration 9
M Help! Can't set up IMAP for gmail Using Outlook 2
P Last Change attribute set after viewing a public folder contact Exchange Server Administration 0
S Multiple Gmail account set up in Outlook 365 Using Outlook 1
Diane Poremsky Add attachments and set email fields during a mail merge to email New Slipstick.com Articles 0
D Script to parse email and set a task Outlook VBA and Custom Forms 1
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
A set onedrive calendar as default in Outlook Using Outlook.com accounts in Outlook 4
reefclaw Outlook 2013 Cannot set outlook.com account as default data file Using Outlook.com accounts in Outlook 3
Q set as default Using Outlook 5
R Notification/alert when an email has been sat in inbox for a set period of time Using Outlook 1
M How to get information about a set of meetings Outlook VBA and Custom Forms 3
K Outlook 2013 Multi Accounts set Default different calendar Sender Using Outlook 2
Emerogork How do I set up an "Incoming mail filter" Using Outlook 12
