Synchronizing subscribed folders causes hanging during send/receive process
Chrisokia
Outlook 2016 64 bit
This is an account I inherited. It has a good 40 folders of which I use 5 or 6. They have items that cannot be deleted and I don't want to archive them. I have a personal outlook account and it has a good amount of folders and does not exhibit this behavior so it seems to be that outlook should be handle this other account.
It does not get a ton of traffic. The folder is about a 1.5Gb.
It takes forever to sync folders causing me to have to wait and sometimes miss emails because they arrive much later than expected.
I followed a post here saying to check/uncheck (can't remember) download headers but I don't see that as an option in Office 365.
I did this and it helped but its still way too slow.
  • Click Query
  • Select all your IMAP folders
  • Click Unsubscribe. Outlook may warn you some folders are ‘special’. Click OK if this warning appears
  • Click OK
  • Close and re-open Outlook.
  • Select your Inbox
  • From the menu click Folder > IMAP Folders
  • Click Query
  • Click Subscribe
  • Uncheck When displaying heirachy in Outlook, show only subscribed folders.
  • Click OK
any thoughts?
The account you inherited is IMAP? Did you try unsubscribing from the folders you don't use?
Go to Send & Receive settings - Ctrl+Alt+S - the check every nn minutes should be set to at least 5 minutes, higher is better. Then click Edit, select the account.
Note, you can also access this dialog from File, Options, Advanced, Send/Receive button or the Send/Receive menu, Send/Receive Groups, Define Send/Receive Groups. I would try disabling the option for Get folder unread count for subscribed folders - and maybe Use the custom behavior defined below - with only the folders you use selected.
Chrisokia
Outlook 2016 64 bit
Yes.,..that is how I have it set up. Only the 2 main inboxes are subscribed too. I keep these clean by moving emails to subfolders so there are maybe 20 emails 20 in the 2 sub'd inbox folders.
Nevertheless Outlook is constantly syncing '5 seconds remaining'
O Outlook 365 - Tasks are not synchronizing? Using Outlook 7
Diane Poremsky Synchronizing Outlook with a Smartphone New Slipstick.com Articles 0
Diane Poremsky Synchronizing Outlook on Two Computers New Slipstick.com Articles 0
P Outlook Keeps Synchronizing IMAP "Sent Mail" Folder Using Outlook 0
D Outlook 2013 stopped synchronizing with my IMAP account Using Outlook 0
J Synchronizing Contact "File As" Using Outlook 2
M Can you stop "Microsft Office Outlook is synchronizing folders"? Using Outlook 2
T Outlook Error synchronizing your folder hierarchy : 80041050. Send Not Receive Using Outlook.com accounts in Outlook 6
H while synchronizing error is coming Outlook VBA and Custom Forms 3
W Outlook contacts not synchronizing with iPAQ BCM (Business Contact Manager) 3
R How to Sync *all* Google Workspace Mail Folders with Outlook 2019 (MS365) Using Outlook 1
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
vodkasoda Hiding empty Folders Outlook VBA and Custom Forms 0
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
R The way expand/collapse folders is actually meant to work? Using Outlook 2
L Merge two contacts folders Using Outlook 1
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
GregS Many Sent Item folders Using Outlook 3
B Reorder folders in Outlook Outlook VBA and Custom Forms 1
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
T Some of my folders in outlook.com appear to have vanished, thanks to v1803 Using Outlook 11
N Tracking Mail items being moved to folders Outlook VBA and Custom Forms 5
oliv- FASTEST METHOD TO ENUMERATE FOLDERS Outlook VBA and Custom Forms 3
F Search folder for tasks in all task folders Using Outlook 1
copperberry How to view all tasks across task folders Using Outlook 3
O Extracting all mail addresses from all folders Using Outlook 10
O Set columns for all (sub)folders Using Outlook 8
