How to get body of all emails in outlook 2016 to view in blue color
AnnaP
I have been working with a client who is using Outlook 2016. He wants the body of all email messages he receives to be in blue. I have been able to change it blue for the message preview, and when a new mail message arrives, but I can't seem to get it to change for the entire body of all emails that he has. Could someone please advise how to make this change? Thanks in Advance.
How To Get Body of All Emails to view in Blue - also note that since any method availavle to make the text blue is applied to all messages, everything will be blue. There isn't a way to have the body blue if unread, black if read.
H Extract emails from Outlokk 2007 email body Using Outlook 0
S HELP: Email body transcript deleted when receiving response emails Outlook VBA and Custom Forms 1
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
A Forwarding email and replacing body Outlook VBA and Custom Forms 1
M Want to autorespond to an email address in the body of message Using Outlook 0
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
S Default Font in body of Task Using Outlook 0
oliv- GetTable Add body Outlook VBA and Custom Forms 4
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
O VBA to extract email (fields and body) to Excel Outlook VBA and Custom Forms 14
J Increase font size of message body Using Outlook 5
Mark Foley Emailing attachment from Word/Excel sends attachment but no message body Using Outlook 0
A Create Macro for hyperlink(email) in message body Outlook VBA and Custom Forms 9
L Copy email body fields to excel Using Outlook 0
