How To Get Body of All Emails to view in Blue
AnnaP
I have been working with a client who is using Outlook 2016. He wants the body of all email messages that come in and that he currently has to be in blue.
(I was able to make it blue for the name, subject and message preview, but I can’t seem to get the entire body of all his messages to be blue.)
Thanks In Advance
You cannot apply conditional format to message bodies. You can change the font settings so the body is is blue for all plain text messages easy enough - but it will apply to plain text messages you compose tho too
You can not change HTML messages using any simple method within Outlook but you can convert all HTML messages to plain text then change the plain text font. It is possible to use a macro to change HTML bodies, but I do not recommend it as it actually edits the message.
I did this by setting Outlook to use plain text for all messages then change the plain text font to blue. (I can change it back to HTML by clicking on the Info Bar text: "We converted this message into plain text format.")
H Extract emails from Outlokk 2007 email body Using Outlook 0
W Anchoring pictures in body of emails Using Outlook 2
T Replied emails dont have the email in the body Using Outlook 2
S Body of Emails Missing in Outlook 2007 Using Outlook 2
N Emails sent from Outlook 2010 are being received with some corruption of the body text Using Outlook 37
K Auto forwarded emails don't contain email body......help! Using Outlook 13
S some emails i recieve the body is blank i use office 2010. windows 7 professional. Using Outlook 3
S HELP: Email body transcript deleted when receiving response emails Outlook VBA and Custom Forms 1
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
A Forwarding email and replacing body Outlook VBA and Custom Forms 1
M Want to autorespond to an email address in the body of message Using Outlook 0
D VBA to edit body of incoming email and forwarding it Outlook VBA and Custom Forms 11
S Default Font in body of Task Using Outlook 0
oliv- GetTable Add body Outlook VBA and Custom Forms 4
H Search and delete part of a link inside HTML body message Outlook VBA and Custom Forms 2
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
O VBA to extract email (fields and body) to Excel Outlook VBA and Custom Forms 14
J Increase font size of message body Using Outlook 5
