Reference Custom Fields with VBA
softwareteacher
Outlook 2019 64-bit
I am attempting to send the Value of an Outlook Custom "Field" to Word. I am able to send any built in Field to Word, but do not know how to send a Custom "Field" Any help would be appreciated.
softwareteacher
Outlook 2019 64-bit
Got It:
.Selection.TypeText ocontact.UserProperties.Find("Custom Field Name").Value
This worked, but anyone with any better ideas would be appreciated.
one way is to grab it as a variable then insert it - its more code but fewer dots
Dim strCustomField As String
Dim propertyAccessor As Outlook.propertyAccessor
strCustomField = ocontact.UserProperties("field name").Value
Are you using a word macro or outlook macro?
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
K How to reference the selected folder Outlook VBA and Custom Forms 1
N VBA Outlook reference to Excel and assigning category Outlook VBA and Custom Forms 13
U Reference Text for VBA for outlook Outlook VBA and Custom Forms 1
M Is there a reference for the valid XML tags and their options? Calendar Printing Assistant 3
N Providing a reference to incoming mail in outlook 2007 BCM (Business Contact Manager) 2
C Shared Calendar Recipient Reference Outlook VBA and Custom Forms 1
E Custom formula for columns Using Outlook 3
witzker Correct Format of custom Yes/No Checkboxes Outlook VBA and Custom Forms 0
O Searching for Custom Flags Using Outlook 3
