Copy Move item won't work
Chooriang
Outlook.com (as MS Exchange)
I need to copy the message from a lot of search folders but the code fails to do so if the code is executed right after executing the advanced search code (on newly created search folder).
What could be wrong? Does the newly created search folder need to be resolved before we can work with its items? If so, how?
Thank you in advance.
Sub GetResult(strAddress As String, strType As String)
    Dim oStore As Outlook.Store
    Dim oFolder As Outlook.folder, tFolder As Outlook.folder
    Dim oNS As Outlook.NameSpace
    Dim oItems As Outlook.Items
    Dim mItem As Outlook.MailItem
    Dim i As Integer
    Dim oExplorer As Outlook.Explorer
    Set oNS = Application.GetNamespace("MAPI")
    'On Error Resume Next
    Set tFolder = oNS.Session.GetDefaultFolder(olFolderInbox).Parent.Folders(strType)
    If Err <> 0 Then
        Err.Clear
        Set tFolder = oNS.Session.GetDefaultFolder(olFolderInbox).Parent.Folders.Add(strType)
    'On Error GoTo 0
    Set oStore = oNS.Session.DefaultStore
    Set oExplorer = Application.ActiveExplorer
    Set oFolder = oStore.GetSearchFolders(strAddress)
    If Not oFolder Is Nothing Then
        Set oExplorer.CurrentFolder = oFolder
        oExplorer.Activate
        'DoEvents
        With oFolder
            If .Items.Count > 0 Then
                Set oItems = .Items
                oItems.Sort "[ReceivedTime]", True
                DoEvents
                Debug.Print strAddress, .Items.Count, oItems(1).EntryID, oItems(1).Parent.storeID, oItems(1).Parent.FolderPath, oItems(1).Subject
                Set mItem = oNS.GetItemFromID(oItems(1).EntryID, oItems(1).Parent.storeID)
                'Set mItem = oItems(1).Copy
                mItem.Copy
                mItem.Move tFolder
        'oFolder.Delete
    'On Error GoTo 0
Chooriang
No matter if strType is hardcoded or passed to it but it does work if I wait.
No error message at all.
JimR Copy or move contacts into BCM? BCM (Business Contact Manager) 1
P I have Outlook 2007 on a two year old computer running Vista. How do I copy my Outlook Contacts list and move them over to Outlook 2010 on a brand new Using Outlook 1
B OL 2010: Move to/copy to folder: how to expand list of options? Using Outlook 2
C Clicking and dragging to moving groups of messages to a folder does not move messages, but creates the action 'copy here as a message...' Using Outlook 5
Z move or copy from PST to Public Folder permissions issue Exchange Server Administration 2
L Outlook 2003 - Changing the Behavior of Drag/Drop from Move to Copy? Using Outlook 1
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
I How to make a copy of a task Using Outlook 8
F copy data in Custom Field to other folder Outlook VBA and Custom Forms 2
A Outlook: copy & paste Outlook VBA and Custom Forms 9
L Copy email body fields to excel Using Outlook 0
