Transport Rule to detect Keyword question..
Post number 2 has been selected as the best answer.
jondw1970
Outlook 2016 64 bit
Good morning, we are attempting to route (to a specific connector that will deal with encryption) outgoing emails that contain a certain keyword - [encrypt]. Although we had some success in testing, we found a few tests failing..
We are using the "subject includes any of these words" and found in the examples below
Working:
Hi, this is a test [encrypt] thanks
[encrypt] test
NOT working
This is a test[encrypt]let me know
Test[encrypt]
So it looks like either the lack of space at the END (or possibly beginning when in the middle) of [encrypt] is causing this to not be detected as a word. Is this expected behaviour on the rule as it's looking for a full word (space before / after) rather than a string of text "within" the subject?
Could anyone point me in the direction if there is another option, such as using 'pattern' (although is that regex?) Many thanks in advance, I have looked for some time through various forums/internet, but cannot see anything that is similar enough to help.
jondw1970
Outlook 2016 64 bit
Working:
[encrypt] test
NOT working
Test[encrypt]
Well, thanks to a very learned colleague, we have an answer if helps anyone. Changing the rule to match pattern and using ((?i)\[ENCRYPT\]) works well! - Thank you
L Transport rule - append disclaimer Exchange Server Administration 1
C Transport Rule Exchange Server Administration 4
E Prevent Looping Message using transport rule Exchange Server Administration 4
V Adding a Transport Rule Exchange Server Administration 3
S Dynamic Signatures? ( Hub Transport Rule? ) Exchange Server Administration 16
P Transport Agent or Rules/Connectors Exchange Server Administration 1
G set exch 2010 server as the default hub transport Exchange Server Administration 6
S Hub transport ex2007 - monitoring inbound Exchange Server Administration 2
D How to manage and configure antispam updates for Hub Transport antispam filter agents at "filesystem Exchange Server Administration 1
S Edge Transport 3rd party mail filter before Exchange 2010 Exchange Server Administration 5
P Exchange transport overheads Exchange Server Administration 4
P Exchange 2010 - Enable Spam filtering on Hub Transport Server Exchange Server Administration 3
C ms transport suite Exchange Server Administration 2
X Internal mail flow between two hub transport servers same domain Exchange Server Administration 10
R Fax Transport Outlook 2010 (32-bit) Using Outlook 12
S Exchange 2010 - Mail Transport Exchange Server Administration 2
D Ms Exchange 2010 - Sp1 Upgrade at Prerequisites on Hub Transport Role Exchange Server Administration 8
T 451 4.4 dns query failed on exchange 2010 hub transport server Exchange Server Administration 1
L Transport Service Issues Message Queue keeps going offline slow mail delivery Exchange Server Administration 1
A Windows NLB for Exchange 2010 SP1 Hub Transport Servers Exchange Server Administration 7
T Prerequisites softwares for installing exchange 2010 edge transport server on windows 2008 R2 Exchange Server Administration 1
D Re: Hub Transport Role Install Fail error # 2147504141 Exchange Server Administration 0
P CAS-Transport-MBX on Single Server Exchange Server Administration 2
J Autoforward from transport hub with changed sender address. Exchange Server Administration 9
D Exchange 2010 Failing to install at Hub Transport Role Exchange Server Administration 11
D Cannot remove Hub Transport role: error code 1638 Exchange Server Administration 13
F Exchange 2010 Transport Service Delayed Start Exchange Server Administration 34
S Database is mandatory on UserMailbox error during install of Hub Transport Exchange Server Administration 19
L Making rule to move email to folder from one O365 domain Using Outlook 1
