BCC issues after changing root folder path for gmail
Biff2020
I set up a gmail account in my Office 365 Home Outlook, the default installation works fine but I don't like the default gmail folder structure. I read I can change that to look like standard Outlook by changing the "Root Folder Path" to [Gmail] - which made the folders look like I want BUT after this change any messages that I send to BCC or forward to BCC without any address in the TO field does not show up in the SENT folder (they do sent, just don't show as sent). I have re-create the issue on 3 different computers and using 2 different gmail accounts. I have other imap accounts in my outlook (comcast, yahoo and outlook.com) now of these have this issue (which did not require the root path to be changed). This is not a critical issue and my work around is that that add my own address in the TO field so that way it will show in the Sent folder. So I was wondering if anyone else has seen this and/or if these is a fix for that? Thanks!
pwatts2 Restrict some lists to only BCC send option Outlook Wishlist 2
M CC AND BCC Using Outlook 1
S BCC lists addressees Using Outlook 2
T bcc and Google imap Using Outlook 3
V Mark BCC when emails is sent from specific account Outlook VBA and Custom Forms 2
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
V using Bcc in Outlook.com 2013 Using Outlook 1
J Cc and Bcc not working Using Outlook 8
K received bcc as encrypted Using Outlook 12
V Contact group: addresses in BCC? Using Outlook 2
C a BCC script question Using Outlook 1
C BCC - How many email address will it accomodate? Using Outlook 2
P help me plase !!! outlook 2007 I can see mail Bcc Using Outlook 1
N How do you BCC Someone Using Outlook 1
S Automatically move recipients to BCC field Using Outlook 3
M Automatic Bcc Using Outlook 2
L automating a BCC on every email Using Outlook 1
M Create Rule to BCC email? Using Outlook 2
H show bcc field when viewing a sent message Using Outlook 15
williamlambton Customised To, CC, BCC and Have-replies-sent-to columns in message lists. Using Outlook 16
L Creating Custom Rule to Forward emails to a BCC Using Outlook 1
T display bcc field in sent emails Using Outlook 1
S Rule to move BCC email to a folder Using Outlook 6
A How to disable bcc option in GAL - Address Book - Exchange 2007 Exchange Server Administration 4
D BCC based upon TO address Outlook VBA and Custom Forms 1
G All contacts from Contact Folder to BCC by code Outlook VBA and Custom Forms 1
G Populate BCC field with all Contacts within a Contact Folder Outlook VBA and Custom Forms 4
S BCC How to? Outlook VBA and Custom Forms 1
R (Outlook2003)Monitor change for "to" "cc" "bcc" on message compose dialog? Outlook VBA and Custom Forms 6
R suppress BCC Outlook VBA and Custom Forms 1
R how to display Bcc if not available? Outlook VBA and Custom Forms 1
P To: or CC: or BCC: Outlook VBA and Custom Forms 4
Y bcc macro Outlook VBA and Custom Forms 1
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
