Macro for reminders,tasks,calendar
userMak
I am looking for a macro which every day at 18:00 will make a list for the next day
reminders
tasks
appointments
and send an email to my google mail in a .txt file
Is it possible?
I have found the following which is working for calendar but not for reminders and it is not in .txt format
Public Sub SendPrettyAgenda()
Dim oNamespace As NameSpace
Dim oFolder As Folder
Dim oCalendarSharing As CalendarSharing
Dim objMail As MailItem
Dim wd As Integer
Set oNamespace = Application.GetNamespace("MAPI")
Set oFolder = oNamespace.GetDefaultFolder(olFolderCalendar)
Set oCalendarSharing = oFolder.GetCalendarExporter
' get the day - send sat/sun/monday out Fri night
' Sun = 1, Mon = 2, Tue = 3, Wed = 4, Thu = 5, Fri = 6, Sat = 7
' none set Sat/Sun
wd = Weekday(Date)
If wd >= 2 And wd <= 7 Then
lDays = Date + 1
ElseIf wd = 1 Then
lDays = Date + 7
With oCalendarSharing
' options are olFreeBusyAndSubject, olFullDetails, olFreeBusyOnly
.CalendarDetail = olFreeBusyAndSubject
.IncludeWholeCalendar = False
.IncludeAttachments = False
.IncludePrivateDetails = True
.RestrictToWorkingHours = False
.StartDate = Date + 1
.EndDate = lDays
' prepare as email
' options: olCalendarMailFormatEventList, olCalendarMailFormatDailySchedule
Set objMail = oCalendarSharing.ForwardAsICal(olCalendarMailFormatDailySchedule)
' Send the mail item to the specified recipient.
With objMail
.Recipients.Add "me@slipstick.com"
' Remove the attached ics
.Attachments.Remove (1)
.Display 'for testing, change to .send
Set oCalendarSharing = Nothing
Set oFolder = Nothing
Set oNamespace = Nothing
Are they flagged messages? I think we can get a list of reminders - will need to check - but most would be covered by tasks and appointments already.
userMak
Yes all they are flagged. (I mean, when I have some mails that someone asks to respond, I right click and then set a reminder for the next day for example in order to pop up and see it and respond)
Most of my work is based on reminders like this. I would like to have a list of my reminders each morning in order to program my schedule.
witzker Outlook 2019 Macro to answer a mail with attachments Outlook VBA and Custom Forms 1
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
G VBA Macro Using Outlook 4
