Going to folder using shortcuts
abadbrad
Outlook 2013 64 bit
I have created 50+ folders and rules for incoming emails.
I have a search for all unread emails.
Does outlook have a shortcut so you can go to the folder of the email in your search?
Let me reword this. My search I have an email and it's in a folder called "Dog". Can use shortcut Ctrl+??? and I would then leave my custom search folder ...and now my view would be the folder "dog" and all the email in that directory?
Thank you....
abadbrad
Outlook 2013 64 bit
OK Thank you, I can find it but it would be nice to be able to right-click and go to the folder or something simple.
Thank you for your quick reply.
That definitely would be great, but its not possible. :(
V Emails going into Drafts instead of Sent folder Using Outlook 3
K Deleted calendar and contact items not going to delete folder Using Outlook 1
K Outlook 2013 Deleted calendar and contact items not going to delete folder Exchange Server Administration 1
V Emails going to Junk folder Using Outlook 2
J Incoming emails going to wrong sub-folder Using Outlook 4
R Emails suddenly going to the Junk email folder Exchange Server Administration 3
H new incoming email going to CONTACTS folder?!? Using Outlook 2
C Forwards and Replies from folders no longer going to Sent folder Using Outlook 2
L Email not going to address displayed Using Outlook 4
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
D Keeps Crasing - going mad Using Outlook 0
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
H Other peoples calendars going on the left Using Outlook 1
Diane Poremsky LinkedIn Social Connector Provider: Going Away New Slipstick.com Articles 1
R IMAP & Outlook 2007: incoming messages still going to old Inbox. Using Outlook 3
wisedave IMAP Mail Directory Keeps Going Empty Using Outlook 5
N Please help....winmail.dat issue...slowly going insane..... Using Outlook 1
A My move to MS is not going too well: Need Help !!! Using Outlook 14
L Reminder default time not going through Using Outlook 7
M Problem/Glitch with unread mail and going back to inbox --- missing emails Using Outlook 1
J Don't want my Comcast mail going to Outlook Using Outlook 1
O Emails still going to Junk Mail Using Outlook 8
J Going from newer to older version Using Outlook 3
M Creating a form....going from one exchange server to another... Outlook VBA and Custom Forms 1
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
M Move to Folder Using Outlook 1
K Export Folder to PST Outlook VBA and Custom Forms 2
B Spam folder not showing in Outlook Using Outlook 5
J Moving Imported folder Using Outlook 2
