VBA script fail after Office 365 update
D.Moore
Outlook 2016 64 bit
After all update since 12730.20236 (including the latest one), this code not running anymore (though it was working perfectly in the last 2 years). I tried to debug it, and it seems, that can not resolve the shared mailbox (though nothing changed on the mailbox and if I restore a previous version of office from backup prior to 12730.20236, resolve it perfectly).
May I ask if you are aware of any change on resolving shared mailboxes since 12730.20236 ?
Maybe this has something to do with it ? :
https://support.microsoft.com/en-us...s-impacted-april-2020-office-security-updates
Many many thanks,
Moore
        Set objOwnerDELETE = objNS.CreateRecipient(email)
        objOwnerDELETE.Resolve
        If objOwnerDELETE.Resolved Then
            Set objSourceFolderMAILBOX = objNS.GetSharedDefaultFolder(objOwnerDELETE, olFolderInbox)
            Set objDeletedItems = objSourceFolderMAILBOX
            Set objDeletedItems = objDeletedItems.Parent.Folders("Deleted Items")
            Set objItems = objDeletedItems.Items
            For i = objItems.Count To 1 Step -1
                objItems.Item(i).Delete
            Set objFolders = objDeletedItems.Folders
            For i = objFolders.Count To 1 Step -1
                objFolders.Item(i).Delete
            Set objDeletedItems = Nothing
            Set objFolders = Nothing
            Set objItems = Nothing
I use this in a app start macro and it works - it's used with an itemadd macro. The only time i have problems is if there are connection problems.
  Set objOwner = objNS.CreateRecipient("accounts@slipstick.com")
    objOwner.Resolve
 If objOwner.Resolved Then
 '  MsgBox objOwner.Name
 Set accountsMailbox = objNS.GetSharedDefaultFolder(objOwner, olFolderInbox)
 Set accountsInboxItems = accountsMailbox.Items
The changes apply to object libraries (Tools > References) , not to this.
D.Moore
Outlook 2016 64 bit
You right, as always! I accidentally placed the debug MsgBox to the wrong place. The problem actually is with my For cycle.
When objItems.Count = 0, so i = 0 , so nothing to delete, then its stuck int the for cycle.
Strange why, as it is always worked till now.
That is weird if it worked before. But the logic is messed up when its 0.
For i = 0 To 1 Step -1
For attachments, I count first and see if greater than 0
lngCount = objAttachments.Count
If lngCount > 0 Then
I have two empty deleted items macros here - Empty Multiple Deleted Items Folders using a Macro - one uses commands, one deleted older items.
D.Moore
Outlook 2016 64 bit
Thank you for your reply!
I had added the deleted items macro into Application_Startup, as I would like to empty the deleted folders when outlook starts up. It works perfecty, BUT for some reason, I creates a strange effect in outlook. Whatever folder I click on, its get cleared, visually. I made a short video about it, and attached it. Could you be so kind and help me why it is, and how to correct it ? BIG thank you in advance!!
'Empty ALL mailboxes Deleted folders - START
Dim olNS As Outlook.NameSpace
Dim objExpl As Outlook.Explorer
Dim mboxCount As Long
Dim i As Long
Dim deletedItemsFolder As Outlook.Folder
    Set olApp = Application
    Set olNS = olApp.GetNamespace("MAPI")
    Set objExpl = olApp.ActiveExplorer
    mboxCount = olNS.Folders.Count
    For i = 1 To mboxCount
    Set deletedItemsFolder = olNS.Folders(i).Folders("Deleted Items")
    If Err = 0 Then
        On Error GoTo 0
        objExpl.SelectFolder deletedItemsFolder
        objExpl.CommandBars.ExecuteMso ("EmptyFolder")
    Next i
objExpl.SelectFolder olNS.GetDefaultFolder(olFolderInbox)
'Empty ALL mailboxes Deleted folders - FINISHED
  • problem.zip
Comment out the last line where it goes back to the inbox, see if that makes a difference.
It looks like the view is goofy as the item count in the lower left doesn't change. Try resetting the view.
D.Moore
Outlook 2016 64 bit
I tried, but thats did not solve the problem. I also reset the view, but this problem only exist, when the code added, if not, there is no problem. Strange.
D.Moore
Outlook 2016 64 bit
I found a work around, adding the script into a schedule, eliminated this strange problem. Thank you !
L Modifying VBA script to delay running macro Outlook VBA and Custom Forms 2
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
R Adding vba to script list Outlook VBA and Custom Forms 4
F VBA script to highlight specific words Outlook VBA and Custom Forms 1
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
M VBA script to allow mail merges of distribution groups? Using Outlook 7
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
V "Accept + Send the Response now", VBA script? Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
L Limit VBA Script to one Outlook account Using Outlook 1
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
