Complite error on SaveAsFile method
Post number 3 has been selected as the best answer.
expat1001
Outlook 2016 64 bit
I posted this before but don't see it. Outlook 2016, working in Access with a reference to Outlook 16
I'm getting this error on attch.SaveAsFile and attch.Item(1).SaveAsFile
"Method or data member not found."
expat1001
Outlook 2016 64 bit
Ooops. Sorry for the error in the subject line. Maybe an admin can edit it (?)
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 5
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 3
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error Using Outlook 0
Diane Poremsky RMS Error: System clock has been tampered with Using Outlook 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet Using Outlook 0
K Error: Paper Size Invalid Using Outlook 0
M Error 0x 800CCC92 Using Outlook 0
Diane Poremsky Cannot start Microsoft Office Outlook Error Message Using Outlook 0
S Autosave attachments error using Len Outlook VBA and Custom Forms 2
