Outlook 2016 remove envelope icon for certain folders
TEK
Outlook 2016 64 bit
Using Win 8.1 64-bit, I run into the following problem when setting up a single Gmail account in Outlook 2016 :
I've created 4 folders under my email address, as seen in the attached Outlook screenshot.
I then create a rule to filter certain emails to each of these 4 folders:
from xxxxx@xxxxx.xxx
move to folder xxxxx
and stop processing more rules
Problem is that when an email is automatically
moved to these 4 folders via rules, then I also receive the Outlook envelope icon in the taskbar.
This is not what I want, and for some reason it was not like this when I used Outlook 2016 and a POP account instead of IMAP.
I also have Spamfighter auto-filtering spam to my [Gmail]Spam folder and the same thing happens there.
I only want to see the envelope icon indicating arrival of new email when something is sent to my Inbox (which I do currently).
Anything that is filtered with rules I don't want to be alerted about.
Does anyone have a simple solution without having to create a bunch of more rules?
Outlook on the web
To remove envelop icon for certain folder in Outlook 2016 you can use these steps
Start-> Personalization-> Taskbar-> Select which icons appear on the taskbar. Locate the entry for Microsoft Outlook that has the envelope icon. Click on the “Off” toggle button to set it to “On” so that the icon won't get hidden automatically anymore.
TEK
Outlook 2016 64 bit
Open Outlook and after opening, option dialog hit the mail. Under the message arrival section on the right side check a show an envelope option in the taskbar and then hit ok.
The "show an envelope icon in the taskbar" is already checked. And I'm not sure if you even understood the problem. I want to remove the envelope icon for mail that is filtered via rules into certain folders.
TEK
Outlook 2016 64 bit
Did I say that the envelope icon is getting hidden automatically?? Read my post again. I am saying that the envelope icon shows up in the taskbar NO MATTER WHAT FOLDER IS RECEIVING MAIL! I only want to see the envelope icon when the default inbox folder is receiving mail.
And in taskbar-->notification area, the program "Microsoft Outlook" is set to "only show notifications". In other words, I am receiving a notification when I am receiving mail and everything works fine. The problem is how to REMOVE the notification for 4 folders, and not how to add it. Sheesh.
That is a long standing problem - it comes through the inbox, the envelope is set, and then is moved. A retired Outlook MVP had a work around for this with older versions of outlook but i don't know if that still works - that was back in the 2003/2007 days. I'll see if i can find her solution and test it. (I don't even recall exactly what it was anymore.)
TEK
Outlook 2016 64 bit
Did you find the work around, Mrs Poremsky?
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 14
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook New Slipstick.com Articles 0
Diane Poremsky Remove Attachments From Messages New Slipstick.com Articles 0
Diane Poremsky Remove Office 2013 Update Banner New Slipstick.com Articles 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File New Slipstick.com Articles 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
K Remove Manage APPS button for users Exchange Server Administration 1
P Remove name and parenthses from email Using Outlook 1
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
Diane Poremsky How to remove the primary account from Outlook 2010/2013 New Slipstick.com Articles 0
Diane Poremsky Remove an Address from Reply All New Slipstick.com Articles 0
Diane Poremsky Remove Outlook apps from Outlook New Slipstick.com Articles 0
S How to remove forms from Organizational forms library Outlook VBA and Custom Forms 2
2 Task has a strike through but is not complete - how to remove? Using Outlook 1
W URGENT Cancel and remove imported pop3 mails Using Outlook 6
T How to remove annoying Big Blue Type at beginning of my messages Using Outlook 2
H Cannot remove unwanted fields from form Outlook VBA and Custom Forms 9
T How to remove "automatically delete messages form this sender"? Using Outlook 1
M How to remove duplicate history items BCM (Business Contact Manager) 7
D Isn't there an easy way to remove duplicate contacts in outlook? Using Outlook 1
Britonius Exchange Powershell to Remove Reviewer access from all Folders in a mailbox? Using Outlook 3
L automatically remove flags Using Outlook 2
