Is it possible it set the fonts used to read incoming mail
e_a_g_l_e_p_i
It seems that all mail I get with outlook 2010 comes in so small, is it possible to set the fonts and size for incoming mail in Outlook 2010? Attached is an example of how small the fonts are on most of my incoming emails
e_a_g_l_e_p_i
Not sure what you are talking about, can you give me instruction on how to do what you suggest?
Vincenzo
Not sure about Outlook 2010, but in 2016 go to View/View Settings/Other Settings
e_a_g_l_e_p_i
That is what I have been doing but it seems that I shouldn't have to on every email. Are there any stable versions of Office besides Office 365 that have any options to use my fonts for incoming emails?
Office 365 lets you set the zoom level - and there is a macro for older versions.
e_a_g_l_e_p_i
I've been using the ctrl button and wheel on my mouse to zoom incoming emails. I was hoping that I could set them so I wouldn't have to zoom manually on each email. I've not used macros before and even though your video tutorial looks very easy to follow I'm a bit hesitant to try it. If I do try it and it works what should I expect outlook 2010 to do to incoming emails? will it allow me to chose a font size for incoming emails or does the macro just set that font to a certain size?
Thanks for your help
The macro sets it to a specific zoom - the "default" is 200%, but you can use any %. It will be the same for all messages though.
Const MsgZoom = 200
e_a_g_l_e_p_i
Thank you very much, I will give it a go. Crossing fingers......lol
e_a_g_l_e_p_i
another thing I noticed is I type a email in my fonts and size and then when I go to send folder and open a email I just typed the fonts are very small, just as most of the emails I get everyday. I haven't tried the macro yet just want to make sure I understand how to do it before I try. Can you explain why when my fonts are correct when I type the email but once it goes to the sent folder the fonts are so small I can't even read it, it all seems strange to me
Ron
e_a_g_l_e_p_i
I followed the tutorial on the macros and was able to get it to work from what I can tell. I have 2 questions, nowhere did I see "Const MsgZoom = 200" this is what I saw in VBA "View.Zoom.Percentage = 150" is that the same thing? here is everything in my VBA. If that is the zoom feature I adjust I can adjust it until everything is a good size for me? each time I adjust the zoom do I have to click on reference,run and make sure I chose those 2 options
Option Explicit
Dim WithEvents objInspectors As Outlook.Inspectors
Dim WithEvents objOpenInspector As Outlook.Inspector
Dim WithEvents objMailItem As Outlook.MailItem
Set objInspectors = Application.Inspectors
Private Sub Application_Quit()
Set objOpenInspector = Nothing
Set objInspectors = Nothing
Set objMailItem = Nothing
Private Sub objInspectors_NewInspector(ByVal Inspector As Inspector)
If Inspector.CurrentItem.Class = olMail Then
Set objMailItem = Inspector.CurrentItem
Set objOpenInspector = Inspector
Private Sub objOpenInspector_Close()
Private Sub objOpenInspector_Activate()
Dim wdDoc As Word.Document
Set wdDoc = objOpenInspector.WordEditor
wdDoc.Windows(1).Panes(1).View.Zoom.Percentage = 150
As always thank you very much
Ron
e_a_g_l_e_p_i
It's been a long time since I posted this thread and I haven't seen a reply to my last question. By chance did you not see my last post?
No, I didn't see it or somehow missed it.
Yes, it is. I don't know why I said 200% was the default. :)
I think it will work when you edit it, but I'm in the habit of clicking in Application_Start and hitting run, just to be sure.
You can replace the 150 with any value you want.
e_a_g_l_e_p_i
I followed your tutorial for the zoom macro and I get the following error message
I made sure that the macro security settings were to allow all macros, then I pasted your code in the VBA and made sure I clicked on word and redemption in references. A screenshot below,
Any idea what may have caused this error?
That's not a macro security error. Do you know which line it errors on?
e_a_g_l_e_p_i
Not sure all it does is give me that VBA error message.
The code I used is the following, is it correct?
Option Explicit
It's working here without error....
In the VBE, Go to Tools, Options and on the General tab, set it to break on all errors. That might highlight the problem line when the error comes up with a debug option.
e_a_g_l_e_p_i
Okay this is what I get now.
here is the code with the highlighted error line
D Is it possible to set up an email rule for a user based on alias address? Exchange Server Administration 3
D Is it possible to set a message as sent programatically? Outlook VBA and Custom Forms 1
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
S Is it possible to cusstomise selectable Options in Kalander. Outlook VBA and Custom Forms 1
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
J Is this possible to do with a macro? Outlook VBA and Custom Forms 17
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
H Is it possible to create a view that only show the first task in a list? Using Outlook 1
H Is It Possible to See Who Has Viewed My Calendar in Exchange? Using Outlook 2
C in outlook 2007-Contact Group-One name have 3 mail id-its possible? Using Outlook 3
J convert .pst to .eml, how is it possible? Using Outlook 1
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
M Is it possible to restore deleted webmail to server? Using Outlook 3
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
D is it possible to have both a POP and IMAP account in Outlook 2013? Using Outlook 5
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Possible to link to ics file without importing? Using Outlook 4
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
B Is it possible with Outlook form Outlook VBA and Custom Forms 5
Steve Jacobs Possible to configure TNEF options based on *sender*? Exchange Server Administration 3
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
E Show field from account on contact form - possible? BCM (Business Contact Manager) 1
A Possible to modify people preview window? Using Outlook 1
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
C Is it possible: List of URL fields BCM (Business Contact Manager) 0
D Frequently used response short cut possible macro Using Outlook 1
Commodore Exporting all contacts to VCF files possible? Using Outlook 4
M I'd like to alter the appointment balloons. Possible? Calendar Printing Assistant 6
J Is it possible to highlight a folder in Outlook 2007? Using Outlook 2
L I want ONE calendar if possible with no overlaying Using Outlook 1
S possible to access my PST file on the Internet Using Outlook 2
N Outlook Rules - is this possible? Using Outlook 3
G Possible to create reports that return contacts based on account criteria? BCM (Business Contact Manager) 0
N Citrix installation possible? BCM (Business Contact Manager) 1
T Is it possible to hide a mailbox but still send on the behalf of. Exchange Server Administration 1
