Autoreply email recieved from specific sender after deleting some text from body.
jalal
Outlook 2016 64 bit
Hi Team,
is there a way where i trying to simplify the maker checker process. i send an email to my checker saying please review the below email and attachment that will be send to the client client_email_id1.com;client_email_id2.com, and checker replies me saying "ok to send". so the requirement is when the checker replies back with "ok to send" it should directly delete the chain of please review and ok to send to...etc and send to the mentioned client ids. Can this be done with some VBA in outlook , you suggestion will certainly help or any other alternatives to simplify the process will be highly appreciated.
one other way i can think of is the maker will send the email draft as attachment and email ids of client in the body asking for review and when the checker replies "ok to send" it should send the draft attached to the senders mentioned in the body.
M Rules and autoreply Using Outlook 1
A Afterhours autoreply from support inbox Exchange Server Administration 1
P i-Phone 6s Plus receiving 2 notifications from Outlook email Using Outlook 1
C WARNING - DO NOT USE AN OUTLOOK.COM ADDRESS FOR GOOGLE ACCOUNT RECOVERY EMAIL Using Outlook 10
T Why is every new email pinned (to keep it on top)? Windows 10 Using Outlook 6
P Can I create a Rule that sends me an email when I get a Task? Using Outlook 3
W Reply to email Using Outlook 4
B disappearing original when attach to email Using Outlook 1
L Email with correct To address but displaying name of a related person Using Outlook 0
A Two Inboxes, Same Email? Using Outlook 3
J To delete the draft email Using Outlook 2
D Sending email from Office 365 alias in Outlook Using Outlook 3
L Outlook saved email templates Using Outlook 1
