Add Form to Appointments Received, Automatically
Outlook 2019 64-bit
Can a Form be added automatically on Appointments received (or accepted)?. I need to track details of all meeting I attend, such as client name, product discussed, client location. This functionality exists on appointments I create by setting Calendar Properties to a specific form - I need to do this to appointments received.
Outlook 2019 64-bit
By jobe, I think I did it:
Option Explicit
Private objNS As Outlook.NameSpace
Private WithEvents objItems As Outlook.Items
Dim objWatchFolder As Outlook.Folder
'Set the folder and items to watch:
Set objWatchFolder = objNS.GetDefaultFolder(olFolderCalendar)
Set objItems = objWatchFolder.Items
Set objWatchFolder = Nothing
Private Sub objItems_ItemAdd(ByVal Item As Object)
' Your code goes here
If Item.Class = olAppointment Then
If Item.MessageClass <> "IPM.Appointment.NewForm" Then
Item.MessageClass = "IPM.Appointment.NewForm"
Item.Save
That should have worked... does it fail on all or just meetings?
if you remove the IF message class line does it work?
Appointments only have one message class
I tested it - it is working. Use a list view and add the message class field to the view - was the message class changed? The ones with the note icon are incoming meetings.
Outlook 2019 64-bit
So... yes I got it to work, thanks to your guidance. Seeing the Message Class is really helpful. I got it to work on my personal Outlook, but not on my employer's Outlook. They must have a macro blocker coming from the outside. So I'll need to create a button within Outlook that triggers the new Message Class on each Appointment I need to change the class on.
Charles
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
makinmyway Can I add a Map It Button to Custom Contact Form? How? Outlook VBA and Custom Forms 6
A "Microsoft Exchange Add-In" (UmOutlookAddin.dll) + Outlook Security Form ... Using Outlook 4
T Add 'Move to folder' icon to custom form Using Outlook 1
H How can you add a URL field in a Outlook Custom Contact form? Using Outlook 6
R Add a link to a custom form Using Outlook 0
P Outlook contact form no longer requiring Category selection to add new Using Outlook 1
0 Add a date stamp to the note field of a custom form Outlook VBA and Custom Forms 1
R Add new type and Custom form on exchange Outlook VBA and Custom Forms 3
L [Outlook 2003] Add Table to form Outlook VBA and Custom Forms 2
J Add Option to remove "Links" area form Navigation Pane Outlook Wishlist 3
U Is it posible to Invoke a custom Form in my Outlook Add-in tool ba Outlook VBA and Custom Forms 1
L did MS ever add way to text via Outlook Using Outlook 3
witzker Outlook 2019 Pls. add a Prefix for OUTLOOK 2019 here Using Outlook 1
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
