Personal Settings within Outlook
guytrey
Outlook 2019 32-bit
I have a couple of laptops running Outlook and I use office 365 hosted exchange. I and my cleints are very picky about there Outlook settings i.e. font read panel settings so on... Is there a way to store those settings in a file (profile) and use it on another Outlook install on another outlook install? Thanks a lot in adance
nialcoxworth
A profile contains configuration information for e-mail accounts and data files and information about where e-mail items are stored. Unlike other Microsoft Outlook 2013 commands and options, editing profiles is done in Control Panel in Windows, not in Outlook. For each profile, you can configure accounts, their settings, and data storage settings.
Exit Outlook.
In Control Panel, click the Mail icon once or twice.
How do I find the Mail icon in Control Panel?
Mail will appear in different places in Control Panel depending on the version of the Microsoft Windows operating system, the kind of Control Panel you have selected, and whether a 32- or 64-bit operating system or version of Outlook is installed.
I can tell you this much: a pst converter isn't going to help you.
Some of the configurations are started in the data file / mailbox, some in the registry.
Views in the message list are hidden files in the mailbox - these are not exported or moved in import export. If you re using exchange mailbox, they will sync over. If you use a default pst, use the pst in a new profile.
You can manually move them or use mfcmapi to move them.
This is how to backup or copy using pst.
B Save account and personal settings, and blocked and safe senders for transfer to a new computer or after reinstall Using Outlook 1
A Microsoft Personal vs Work Accounts in Outlook Using Outlook.com accounts in Outlook 7
A Created a personal group that now appears to be a public group Using Outlook 3
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
D Winmail.dat with MS Exchange Personal and Outlook.com Using Outlook.com accounts in Outlook 5
L Receiving work/Exchange email to my personal email Using Outlook 2
Diane Poremsky Repair a Large Outlook Personal Folders File (over 2GB) New Slipstick.com Articles 0
Diane Poremsky To Secure Your Personal Folders (*.pst) File New Slipstick.com Articles 0
Y Move new messages to personal folder which already contains this conversation Outlook VBA and Custom Forms 1
O Missing guide "Move an Outlook Personal Folders .pst File" New Slipstick.com Articles 4
Diane Poremsky How to repair a damaged Outlook Personal Folders file (pst) New Slipstick.com Articles 0
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) New Slipstick.com Articles 0
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
LeeDock Office 365 Personal Backup strategy Using Outlook 1
M Move Sent Items from server folder to personal folder Using Outlook 2
Sue IMAP account personal folders disappeared Using Outlook 1
F Sync Sharepoint Calendar With Personal Calendar Outlook VBA and Custom Forms 5
R Contacts/Personal Folders, etc Using Outlook 5
O Personal Folders Backup aftermath Using Outlook 5
Alex Hall When updating shared calendar, it does not automatically update personal calendar Using Outlook 3
V question about personal and shared calendars Exchange Server Administration 1
D Move Personal Forms Library Outlook VBA and Custom Forms 10
R How to copy outlook 2010 shared calendar appointment or meeting to personal calendar by vba? Outlook VBA and Custom Forms 1
K How to make use of outlook calendar, contacts & tasks using personal POP3 mail Using Outlook 1
S Setup many personal calendars on outlook 2013 on new laptop- starting over Using Outlook 1
A How to add personal notes to a meeting - and keep them if update sent? Using Outlook 1
B Contact changes from Personal to Shared when opening custom form Using Outlook 0
S Deleting Personal folder and IMAP account PST files Using Outlook 0
H Moving emails in shared mailbox to personal mailbox Exchange Server Administration 0
T 2010 Personal Folders Question Using Outlook 10
S Calendar updates wipe out personal notes. Using Outlook 3
Z Making Outlook Default folders to local/personal instead of Hotmail Using Outlook 8
C stop messages to personal folders Using Outlook 2
H ran scanpst.exe and that fixed most, but cannot access personal folders Using Outlook 1
R Can't close Personal Folders after switching to Exchange 2010 Using Outlook 2
M How to Create Macro in Visual Basic to add Contacts from Personal Folder Using Outlook 4
H Personal Contacts Using Outlook 4
I Personal Folder List Problems Using Outlook 3
A Remove personal contacts script Exchange Server Administration 2
N Personal Distribution Lists Using Outlook 0
C Keep personal maps structure when reopening OUTLOOK 2010 Using Outlook 1
A Shared calendars and personal calendars Using Outlook 1
G I have two mail boxes open, my personal company mail address and a department inbox . When I delete an item from the deparment nbox it goes into the d Using Outlook 1
J Does anyone know if there is a theoretical limit to the number of personal folders permitted within Using Outlook 2
R Exchange 2010 Personal Archives Permission and Delegate Access Exchange Server Administration 1
B Is personal archive email is cached in server memory? Exchange Server Administration 5
M follow up flags in personal folder Using Outlook 1
K Windows Installer runs when moving email from Inbox to Personal Folder Using Outlook 1
