Outlook view grouping keeps changing
Post number 3 has been selected as the best answer.
Emm
Outlook 2019 32-bit
Outlook.com (as MS Exchange)
I have a message view set up to group by email account. Though I have changed this setting (with others) into a saved view, the grouping changes on me, periodically.
Is this a known problem? I'm using Outlook I-don't-know-what-version, downloaded as part of my school district's Office 365 plan.
Did you customize the default view? Try creating a custom view and see if it works better. But if you change anything it will be 'saved' to the view.
Once you get the view the way you like it you can use a macro to lock the view from changes. You'll be able to make temporary changes by when you leave the folder and return, the changes will be gone.
Emm
Outlook 2019 32-bit
I appreciate your knowledge - I'm *so* dependent on Outlook, and know it can do most things I need it to -- it's just not always obvious how...
R Outlook 2010 Conversation View isn't grouping my conversation Using Outlook 8
K Accentuating today in Outlook calendar month view Using Outlook 2
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
B outlook view control Outlook VBA and Custom Forms 0
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
Diane Poremsky Disable Protected View for Outlook Attachments New Slipstick.com Articles 0
A Need to view Outlook calendar in Sharepoint .. Using Outlook 2
O highlighted dates in Yearly View for Outlook 2010 Using Outlook 1
V View calendar on backed up Outlook file Using Outlook 6
F Outlook 2007 Calendar Appointments not in Outlook Today view Using Outlook 11
P Outlook 2013 Conversation View vs. 2007 Using Outlook 1
Horsepower How to restore default view Outlook 2013 Using Outlook 8
P Outlook 2013 Tasks - default view Using Outlook 1
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
G Outlook 2013 - Default View for Public Folder Contacts Using Outlook 1
Paul Van Cotthem Outlook 2013 contact picture only visible in "People" view Using Outlook 4
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
M Outlook 2013 conversation view ... missing links Using Outlook 3
E outlook 2013 --->actions ---> view in browser, is there a way to change the Using Outlook 1
M View in browser stopped displaying .GIFs in Outlook 2010 Using Outlook 1
D Outlook 2010: Conversations view - most recent activity posts to of inbox? Using Outlook 2
T Error" There are no items to show in this view" for Outlook 2007 with 16GB pst Using Outlook 2
D How to show just the date in an Outlook 2010 Journal view Using Outlook 1
S CHANGE DEFAULT VIEW FOR CONTACT (People) SEARCH - Outlook 2013 Using Outlook 3
R View who sent on behalf of a shared mailbox in Outlook sent items Using Outlook 1
F Combine Outlook Task Folders into one View (Outlook 2013) Using Outlook 3
A In Outlook 2007, need to see the replied/responded date in Inbox view Using Outlook 3
G Outlook 2013 contact view keeps resetting Using Outlook 1
O Calendar list view in Outlook 2010? Using Outlook 3
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
P Using Outlook to view Office 365 e-Mail Using Outlook 1
C Outlook 2010 won't use a view other than maximized Using Outlook 1
P Adding a g-Mail account to view in Outlook Using Outlook 2
D Outlook 2010 - Calendar - always show 4 weeks in month view Using Outlook 3
K Specific outlook view Using Outlook 1
M Folder View in Unread Mail Pane - Outlook 2003 Using Outlook 6
M Outlook Calendar Monthly View Missing Appointments Using Outlook 3
