Outlook WAS facebook but there is no info for old accounts
willythecat
Sorry everyone, but it's no wonder MS is getting a bad reputation nowadays, mainly because the "aftersale" service is totally cr**!
I have 2 hotmail accounts, one of which l really must keep.
The other was a test account so that if l wanted to try out anything, it went to that account and didn't ruin my true account.
l also have an outlook account, hence l can login to here. The way to go l suppose, but am really reluctant to use it.
Now, when l login to anything "facebook", it comes up with this second facebook account name.
Because it was many moons ago now, I have forgotten the password.
Select "forgot" password and guess what, you've got to sign in to the account to get the new one?
Well l don't know what bozo at MS came up with that great new idea!
How the heck do l get rid of this old second hotmail account then?
O Outlook 2016 0x800CCC0F 'The connection to the server was interrupted' Using Outlook.com accounts in Outlook 1
C Whose brilliant idea was to make it more difficult to scroll in Outlook? Using Outlook 0
D Will Outlook 2010 work with Office 2013 H&S that was preinstalled Using Outlook 2
E My Outlook 2010 contacts list was hijacked! Using Outlook 10
P Was Helvetica crashing Outlook, now fix has messed up explorer Using Outlook 4
P the outlook 2007 calendar cannot be saved because it was changed by another user or in another windo Using Outlook 4
J Can't run macro Outlook 2007 that was created in Word 2007 Outlook VBA and Custom Forms 1
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 13
@ Outlook Using Outlook 2
