Two Inboxes, Same Email?
amesgrad
Outlook 2016 64 bit
Hi!
We recently upgraded our email host from Siteground to GSuite (iMap). Now, there are two inboxes in my Outlook, both for the same email address - one is associated with the old account, and one with the new. I need to get rid of the old account/inbox without losing info. Suggestions??
Guidance is appreciated!
Was the old account set up as pop? If so, that is the pst file the account used. Go to File > Account Settings > Account Settings to open the Account Settings dialog. Look on the data files tab and remove the old one. It should have a pst extension and be in documents folder path.
saurabhjha
Outlook on the web
you can use direct backup software which helps you to backup the files with attachments easily, many of them also provide demo version you can use that for the backup.
amesgrad
Outlook 2016 64 bit
Thank you Diane
I believe so. I can see two files in the Account Settings. However... We did a data migration and brought everything over from the old account into Gmail. Then we setup Outlook. Right now, there is an Outlook app icon on the bottom bar (pulls the old account) and one in the middle of the screen on desktop (pulls the new account). I need to make sure that all the folders are preserved from the original mailbox while only pulling in the emails that have come over from GSuite since we ran a migration that includes email going all the way back to 2008.
I would then want to get rid of the inbox not needed so it's not confusing. Biggest concern is not losing folders and info that were associated with the old email. Is that possible??
I'm attaching a screen shot - not sure how well you can see it as it's so small and blurry, but there are two inboxes that are the same email. Thanks for all the help/guidance.
L Multiple Inboxes Using Outlook 3
mctabish Replying to an email if received in several inboxes Outlook VBA and Custom Forms 2
T OL 2007 two inboxes and two send folders Using Outlook 3
B Two Inboxes after upgrade, how to merge? Using Outlook 4
T Reinstalled OL2010 now have 3 separate inboxes and contacts missing Using Outlook 2
J i WANT TO SEPERATE 2 ACCOUNT INTO DIFFERENT INBOXES. Using Outlook 1
E Multiple inboxes Using Outlook 2
J Blank Inboxes in Outlook 2010 Using Outlook 3
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
N Move emails of same conversation to same subfolder Using Outlook 6
I get count of all emails with same conversation ID Outlook VBA and Custom Forms 2
R Shortcut for attaching the same file repeatedly Using Outlook 6
M warning for too many appointments on a same day in Outlook Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
M Why delivery receipt size is same than sent email size or even larger? Using Outlook 1
C How to copy same text header to multiple emails with custom text column Using Outlook 10
D Calendar - color coded items are now the same color Using Outlook 2
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
B Mail on both laptop and mobile at same time Using Outlook 2
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
L Delete code and commandbutton at the same time. Using Outlook 1
njs27 Start date of occurrence same as PatternStartDate Outlook VBA and Custom Forms 6
G How to let data in an account user defined field appear in the same field all related opportunities BCM (Business Contact Manager) 1
L IMAP and POP email in same Outlook system Using Outlook 1
A Use same BCM data in 2 offices BCM (Business Contact Manager) 3
A After receiving the same email 3 times, Outlook starts sending it to junk Using Outlook 1
K Help! I selected every contact and mistakenly made them all the same category Using Outlook 1
S Searching contacts across GAL and local address book at same time Using Outlook 1
D Move email to same folder as the rest of the conversation Using Outlook 1
J How to create fields that will use the same value on different record types BCM (Business Contact Manager) 2
R View two Inboxfolders at the same time in split creen Using Outlook 1
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
D ActivitiesTab in OL2000 - same functionality in OL2013? Using Outlook 1
B Excel 2010 vba to post appts to different outlook calendars at the same time Using Outlook 6
J outlook problem it allow to book meeting room at the same day & time Using Outlook 0
Z Keep Unread Messages in same folder Using Outlook 2
D Multiple Users Updating Custom Form At Same Time Using Outlook 1
K Save a received email in a mailbox subfolder which is the same as the @email Using Outlook 1
Commodore Renamed folder staying at the same position Using Outlook 3
