Free/busy publish at http location does not work
Nicola
Outlook 2007
I followed the Microsoft instruction to configure the Outlook app to publish the Free/busy information, but it seems that it does not work.
In options > Calendar > Free/Busy Options... I added an HTTP resource such as
Outlook makes calls, but these are OPTIONS HTTP requests with, of course, no data.
Creating a file in a shared folder (format file://\\) works.
I do not have an Exchange account connected.
Thank you for your help.
FitBoy01
Outlook 2019 64-bit
I just finished a hybrid and had same issue with my site, I followed all the documentation from Microsoft but no luck. Finally I restarted the IIS site on the on prem CAS server and it started working.
Might be worth a shot if you haven’t rebooted that server since hybrid was established.
Diane Poremsky Change the All Day Event Default Free/Busy to "Busy" New Slipstick.com Articles 3
A export free / busy from exchange Exchange Server Administration 0
M print free/busy schedule of an user Using Outlook 2
S Is Free/Busy supposed to work in Outlook 2013 not connected to Exchange? Using Outlook 14
S edits to free/busy fielddon't show up in meeting requests Using Outlook 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
P Appearance (Width) of Calendar Appointment "Show as (Free/Busy/etc)" Indicator Using Outlook 1
B Outlook 2003: Meeting Organizer will be set as always free or busy status Using Outlook 1
T Outlook 2003 free busy vfb file creation problem Using Outlook 12
S You’ve received Free/Busy information from this user Message Using Outlook 10
S Is there a free version of outlook? Using Outlook 0
O Get Outlook on your phone for free - web page pop up Using Outlook 8
W FYI: CodeTwo Sync for iCloud is FREE now! Using Outlook 0
V [FREE OUTLOOK ADDONS] Outlook Freeware! Using Outlook 0
T Outlook 2007 forms: Check boxes and free text boxes not retaining data Using Outlook 1
G Synchronize outlook contacts and calendar with other pc for free Using Outlook 4
M Not enough free memory BCM (Business Contact Manager) 11
C Business Contact Manager and Outlook 2007 "not enough free memory BCM (Business Contact Manager) 5
J Outlook won't open. PST file busy. Using Outlook 3
J Other user's calendar view showing as busy in 2007 & 2013 from my account Using Outlook 1
S Copy Events to Second Calendar or Sync Only "Busy" Events Using Outlook 5
M Cannot Publish Calendar to Office.com Exchange Server Administration 9
P Publish to Outlook.com Using Outlook 0
D outlook calendar publish to webdav Using Outlook 2
S Custom property/functionality not stored when I publish to a Public Folder Using Outlook 7
S Where to publish my custom form ? Outlook VBA and Custom Forms 4
K Publish form to folder - Outlook 2007 Outlook VBA and Custom Forms 1
Z Publish new form to all contacts Office 2003 Outlook VBA and Custom Forms 3
