Unflag Inbox and Flag Inbox with Orange Category After Item is send
alvinoo
Outlook 2019 64-bit
Sub ReplyMSG()
Dim olItem As Outlook.MailItem
Dim olReply As MailItem ' Reply
For Each olItem In Application.ActiveExplorer.Selection
Set olReply = olItem.ReplyAll
CopyAttachments olItem, olReply
olReply.HTMLBody = "Hi,please follow up"
olReply.Display
'olReply.Send
Next olItem
Hi there,
How do I flag the send item with a category and items with a flag,
and unflag the inbox item.
IF and only IF the item is sent?
Do you want to flag the sent item or the inbox items with a flag?
This will flag the selected item,. add a category and adds the quoted message, preserving the HTML format to the outgoing message.
Sub ReplyMSG()
With olItem
' due this week flag
    .MarkAsTask olMarkThisWeek
' sets a specific due date
    .TaskDueDate = Now + 3
    .FlagRequest = "Call " & .SenderName
    .ReminderSet = True
    .ReminderTime = Now + 2
    .Save
With olReply
.Categories = "Follow up"
.HTMLBody = "Hi,please follow up" & vbCrLf & olReply.HTMLBody
.Display
'.Send
Next olItem
alvinoo
Outlook 2019 64-bit
Hi there,
I want to flag the sent item.
So i just change the code to the following right?
With olReply
.ReminderSet = True
.Save
Yeah, adjust the values as needed. Depending on your configuration, it may set a flag in the recipients mailbox,. to avoid that, you need to use a macro that watches the sent folder and flags messages in that category.
P unflag sync'd emails Using Outlook 3
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
E Outlook 2016 Inbox search bug Using Outlook 1
LolaArrabal My huge inbox folder Using Outlook 2
M Emails being sent to Inbox and IPM_Subtree Using Outlook.com accounts in Outlook 4
S Accepting meeting request from calendar keeps the meeting request in the inbox Using Outlook 2
E Inbox field customization Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
Diane Poremsky Category Color doesn't Display in Inbox New Slipstick.com Articles 0
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
A Can't add a column called "name" to Inbox? Using Outlook 1
V Not displaying newest messages in Inbox Using Outlook 10
Yasemin Nielsen Combined inbox outlook 2016 Using Outlook 2
D How to Run a Report Based on Age of Inbox Items Outlook VBA and Custom Forms 0
R Tasks showing up in inbox? Using Outlook 15
