VBA unknown character
Post number 2 has been selected as the best answer.
Lacisnesnon
Outlook 2019 64-bit
Hi all,
I have emails with subjects from a specific authority that includes a special character. It shows up as a couple of spaces or a tab in the email subject in Outlook, however, when manually file saving the target email Outlook has already removed this character from the subject.
email_subject-png.22299
I have a file saver macro module that processes a selected email and saves it to a predetermined location, however, when it extracts the subject from the email it includes this special character which shows up in the error message as a SQUARE (not [] as there are no pixel spaces between the two brackets). See attached images for examples.
email_subject_vba_save-png.22300
I have tried processing all special characters that I am able to with no resolution. "#$%()^*&/\:;*?<>+[]." The error still persists.
I guess the only other way is to write code that will process each character in a string until there is an error which then records the error character number in the string and replaces it with something valid. I don't want to have to do this for all emails.
Any ideas would be appreciated.
Thanks in advance
You can use the clean or cleanstring functions (but need to reference Excel or Word) to remove non-printing characters on the low end of ASCII, but need to use replace to remove ones above 31 (like non-breaking spaces). sometimes It's just easier to use replace for specific characters codes.
