Flag Message for Follow Up after sending
alvinoo
Outlook 2019 64-bit
Hi there,
Is there anything wrong with this code.
Sometimes it work sometimes it doesn't work.
Idea is to have an options to flag follow up items for Sent Email.
Private Sub olSentItems_ItemAdd(ByVal Item As Object) On Error Resume Next Dim prompt As String prompt$ = "Do you want to flag this message for followup?" If MsgBox(prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Add flag?") = vbYes Then With Item .Categories = "Orange category" .FlagRequest = "Follow up" .Save End With End If End Sub
it looks good. Is the question not coming up every time or does it come up but the flag isn't set?
If it's not bringing up the question, comment out the on error resume line - that should bring up the debug message if it errors and you might be able to figure out which line is the problem.
B on flag message event - create task Outlook VBA and Custom Forms 22
A automatically remove flag from original message when a response was received Using Outlook 2
E Remove flag automatically Using Outlook 4
T Can't reposition "Flag Status" column Using Outlook 0
R Outlook 365 update sets delete from server flag Using Outlook 2
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
G Flag for Follow Up with a customized duetime Using Outlook 1
Diane Poremsky How to Easily Change the Private Flag Using Outlook 0
A Flag outgoing email messages in Outlook 2010 Outlook VBA and Custom Forms 0
mikolajek Add on for customized flag operations? Using Outlook 4
A Custom Flag Form Outlook VBA and Custom Forms 2
mikecox Missing alarm flag Using Outlook 2
smokiibear follow-up flag fro Tasks in Outlook 2010 Using Outlook 5
D Create additional custom flag descriptions (other than Send E-Mail, Call etc.) Using Outlook 1
A Post Form Follow Up Flag Using Outlook 4
S Flag Completion Using Outlook 0
F Apply Follow up flag ONLY to the people cc'd. Using Outlook 1
J Macro to periodically sort emails by flag status? Using Outlook 1
2 Flag for Follow up or create new task Using Outlook 1
L Flag settings Using Outlook 1
M Flag outgoing mail by word in body Outlook Wishlist 1
D Setting the Reminder flag in VBA for e-Mails sent to users Outlook VBA and Custom Forms 5
S Adding follow flag for me by macro (MSO2007) Outlook VBA and Custom Forms 3
Commodore Unable to move message Using Outlook 3
S Unable to change Message Class Outlook VBA and Custom Forms 0
S Changing Message Class Outlook VBA and Custom Forms 4
Cathy Rhone Mail merge error message Using Outlook 2
