Shortcut Pane - add shortcut to Office365 group mailbox
peedoe
I use the shortcut pane instead of the mail pane so I can see folders from multiple email accounts in the order I want. However, I can't seem to figure out how to add a shortcut to an office365 group mailbox. It doesn't show in the list of accounts when I try to add a shortcut, but they are all listed under groups in the email pane.
M Shortcut to another outlook item Using Outlook 0
R Shortcut for attaching the same file repeatedly Using Outlook 6
M Contact group shortcut Using Outlook 3
S Shortcut/button to a Calendar Group Using Outlook 0
B Can't create shortcut to Quickparts Using Outlook 3
iwshim word shortcut to search outlook Using Outlook 3
O Address Book Shortcut Using Outlook 4
S Desktop shortcut Using Outlook 1
Q shortcut to more stationery Using Outlook 4
A Shortcut for sending complete mail Using Outlook 1
I jump to body in open message with one keyboard shortcut? Using Outlook 3
T Column Header Keyboard Shortcut Available? Using Outlook 5
D Selection of Send-From Account with Template VBA Shortcut Using Outlook 0
W keyboard shortcut to open Outlook... ? Using Outlook 2
S OL 2010 shortcut to edit received mail Using Outlook 3
L Shortcut to specific contact Using Outlook 4
C Want to Create Shortcut to Open Specific Calendars at the Same Time Using Outlook 2
S Shortcut for adding a recepient email id? Using Outlook 2
E Outlook Calendar Shortcut Using Outlook 3
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
B Outlook 365 - Folder pane list clears Using Outlook 24
R Folder pane width change Using Outlook 59
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
GregS What controls content of Folder Pane? Using Outlook 1
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 14
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
N Outlook People Pane - Sent Mail Using Outlook 1
