Outlook 2019/O365 Build 13127.20408 errors when using MAPI calls
pcunite
Outlook 2019 64-bit
When attempting to initialize MAPI, or perhaps starting Outlook with 3rd party addons, error 0x80004005 will always be returned. Then the PreFirstRun dialog box will display everyone's favorite message: "Either there is no default mail client or the current mail client cannot fulfill the messaging request. Please run Microsoft Outlook and set it as the default mail client."
The current workaround is to roll back to the August 25 Version 2007 (Build 13029.20460) build. I don't know the exact build that introduced the error, just that this one work for me.
Tell the folks in Redmond for me. Thanks!
When I asked Microsoft about it, they thought the no default mail client error is solved following the steps in this article:
There is a mapi bug I just don't know if it is related to this or if it was caused by that update.
witzker Outlook 2019 is cutting Picture Extension *.pn_ Using Outlook 3
A Outlook (and Office) 2019 Logging Using Outlook 2
witzker Open Contact missing in Outlook 2019 Using Outlook 2
C All Gmails don't show in Outlook 2019 Using Outlook 2
J How do I disable advertising in Outlook 2019? Using Outlook 13
R Outlook 2019 Using Outlook 0
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
W Outlook 2019, Outlook Proplus v1808/1809 Unexpected Calendar Cache Using Outlook 4
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 0
D Outlook.com premium finally dying... what do I do with my domain? Using Outlook.com accounts in Outlook 3
S Is there a free version of outlook? Using Outlook 0
peterbata Shared Tasks Outlook for Mac Using Outlook 2
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
S Excel vba code to manage outlook web app Using Outlook 8
K Outlook tasks formatting Using Outlook 4
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
H I have no profile listed for Outlook! Using Outlook 9
D Outlook 2016 how to use gmail account as source account for outlook 365 Using Outlook 9
Horsepower Contacts added from iPhone don't show up in Outlook Using Outlook 1
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
L Outlook saved template function too limited Using Outlook 2
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
