Macro for other actions - Outlook 2007
Steve Mc
I’m used to recording macros in Excel, but don’t know how to do that in Outlook 2007.
When receiving an email that has been replied to 4 or 5 times or more, often portions if the original message, or even some of the previous responses, are changed to very large fonts, usually 120 point.
Also, often some the previous responses are formatted with one word per line on the far right.
Like
this
it
makes
for
long
emails.
I have to manually Select all-Other Actions-Edit Message, change the Font to a reasonable size like 12, then exit to save. That will at least fix the large font problem.
I would like to have a macro do that to specific chosen emails , but do not know how to even begin to write it.
I’d like to also have the vertical problem fixed too, but not sure if that is possible.
That is often due to an antispam scanner corrupting the CSS by removing the dot/point in 12.0 MacAfee had a habit of doing this off and on. I don't know if it still does... the other possibly is the user has zoom set low and changed the font so they can see it.
This can be caused by someone adjusting the margins in email, like they would in word, instead of adjusting the window size. The markings as 'in from left, in from right' so if someone opened a new message at full screen and adjusts the right margin so its more like a 80 character wide, the margin might be 6" in from right - it may not be noticeable at first, but one or two indented replies can condense it enough to be a problem.
To fix a wide screen - resize the new mail window, like this:
Don't change the margins, like this, it will squish the lines when the message is read in a smaller window.
Steve Mc
The other receiver/sender is usually emailing from an Ipad, and does not change any other settings, just replies as is. Also MacAfee is not involved in these cases. Note that the large font and vertical formatting usually doesn't happen until maybe the 5th or 6th reply.
So can there be a macro to do the following on an opened email that is displaying some 120 pt. font size: Select All-Other Actions-Edit Message-Format Text- (select) 12 point font- Exit - Save ?
Yes, a macro can fix that. I will see if I have one - if not, vboffice.net might.
I have this one - if the font size is always the same 120px, I'd have it look for the font attribute and change it. It might be in the message list this:
style="font-size:120pt;font-family:"Arial&quot...
so you'd have the macro look for font-size:120pt and replace it with font-size:12.0pt
there is a sample on the page that changes the email font
Steve Mc
Thank you. Unfortunately, they're not always the same size. I just used 120 pt. as an example. Others are 150 pt. font. I've already manually changed prior ones to all 12 pt., so I'm not exactly sure what those sizes were. And that's why I just thought the easiest way would be to select the entire email message, and change all fonts to 12 pt. In fact, that's what I'm doing manually. The Arial, New Times ,etc, does not matter. I'll keep those what they are.
I'll see if I have one that can do the whole message list that.
I don't have one already that does it - will need to wrote one. It would be a select all and change the font size - it should be easy enough. I'll take a look tomorrow.
Oh wait - I have this one. It works on the selected text - but doesn't select the entire message.
This will select the entire message - use it before the font change.
With objSel
'use wholestory to copy the entire message body
.WholeStory
Steve Mc
OK,that's a start. Thanks.
But woukld it be to much trouble to give me a step by step process, because I have absolutly no experience with Outlook marcos ?
This code will change the font since of the message to the specified size. I didn't test it in 2007, but it should work. You need to set a reference to word object model.
 Public Sub FormatSelectedText()
    Dim objItem As Object
    Dim objInsp As Outlook.Inspector
    ' Add reference to Word library
    ' in VBA Editor, Tools, References
    Dim objDoc As Word.Document
    Dim objSel As Word.Selection
'Reference the current Outlook item
    Set objItem = Application.ActiveInspector.currentItem
    If Not objItem Is Nothing Then
        If objItem.Class = olMail Then
            Set objInsp = objItem.GetInspector
If objDoc.ProtectionType = WdProtectionType.wdAllowOnlyReading Then objDoc.UnProtect
' replace the With block with your code
       With objSel
       .WholeStory
       ' Formatting code goes here
            '.Font.Color = wdColorBlue
            .Font.Size = 12
            '.Font.Bold = True
            '.Font.Italic = True
            '.Font.Name = "Arial"
objItem.Save
    Set objItem = Nothing
    Set objWord = Nothing
    Set objSel = Nothing
    Set objInsp = Nothing
Steve Mc
OK I'm not really sure what I am doing, but I copied the above into a module(project 1). Then I manually selected all the text in an email, and then went to Tools - Macro - Macros, and selected the macro and ran it, I received a compile error, user defined type not defined,
and this was highlighted -> Dim objWord As Word.Application
You need to set a reference to the word object model in tools > References. There is a screenshot of the dialog at the end of the article
You don't need to select the test in the message - just open the message and run the macro.
Steve Mc
Ok, I did that, and I have 4 items checked:
Visual Basic for Applications
Microsoft Outlook 12.0 object library
OLE Automation
Microsoft Office 12.0 object library
But get the same compile error. I said OK. Is there something else that should be checked ?
It should work - I'll test it in office 2007 in the morning.
It worked fine for me when I added the reference to the word object - open a message, run the macro.
Steve Mc
For some reason, I do not have that Microsoft Word 12.0 Object Library as an available reference.
Steve Mc
Is there a way I coulds get the Microsoft Word 12.0 Object Library? Or some other method ?
witzker Outlook 2019 Macro to answer a mail with attachments Outlook VBA and Custom Forms 2
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 14
G VBA Macro Using Outlook 4
