Modifying the built in forms with VBA
vincetaylor
Outlook 2016 64 bit
I created an Outlook form by taking one of the existing built in forms in my personal folder and adding new fields.
I would now like to make some changes that require code. As an example, I would like to add VB code to the form that says if the Summary field is empty then the name field becomes inactive
Question: How do I access and modify the code for this form?
I clicked on the "View Code" button and it displays an empty file
When I clicked on the Visual Basic button, I don't see the code for this form. I only see a generic form called UserForm1. See image below
vincetaylor
Outlook 2016 64 bit
Another question I have is about publishing a form created in VBA
Question: Once you create a form in VBA, How does one Publish the form to one of the Libraries e.g. Standard Forms Library or Organizational forms Library or Person forms library.
How for example would I publish Userform1 above for use by myself or others ?
I don't see the Publish option in VBA
You click View code - but need to add the code. If all you need to di is make sure a field has a value, use Validation. Right click on he field, choose properties then Validation.
When you save the entry with the field blank
You don't publish it using VBA. :) If you are not using Exchange with an organizational forms library or publishing it to a shared folder, you'll need to give the form to the others to share it. They'll publish it to their personal library.
vincetaylor
Outlook 2016 64 bit
Thank you very much for your response. I am only now starting out with VBA for Outlook forms.
I clicked on the View Code button to open the editor. Then I tried some basic code to see if I could control a button. Then I saved and published
But when I run the form click on the button, nothing happens
The Code I tried is
Sub CommandButton1_Click()
msgbox "Hello World"
Why am I still unable to control the button?
vincetaylor
Outlook 2016 64 bit
Just FYI. I have also enabled macros. I would like to get this basic code working so I can proceed with learning on the job
I Outlook 2013 Modifying an Outlook calendar Using Outlook.com accounts in Outlook 0
M Modifying Macro MoveAgedMail(2) - use categories & "to" as variable Using Outlook 12
B modifying print template for printing out appointment details Calendar Printing Assistant 2
S Automatically modifying an email Outlook VBA and Custom Forms 3
U Creating or modifying Outlook .Nk2 file in C# Outlook VBA and Custom Forms 1
A Expected behauvior when modifying properties? Outlook 2003. Outlook VBA and Custom Forms 3
C Beginner Needs VBA Help in Modifying Code Outlook VBA and Custom Forms 2
J Modifying a Business Contact Manager Report BCM (Business Contact Manager) 1
Fozzie Bear Wishlist A built in Archiving system that allowed storage of messages on a normal file server Outlook Wishlist 1
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
F KB4475563 stops VBS at forms working Outlook VBA and Custom Forms 3
N Creating a button or link to a form in the Organizational Forms Library Outlook VBA and Custom Forms 3
M other user's mailbox won't open, forms disappeared Using Outlook 42
B Outlook Custom forms Using Outlook 0
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
Diane Poremsky Create an Organizational Forms Library New Slipstick.com Articles 0
Diane Poremsky Create an Organizational Forms Library in Exchange 2013 or Office 365 New Slipstick.com Articles 0
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
Cameron Piper Automatically update custom forms across multiple computers Outlook VBA and Custom Forms 1
F Organizational Forms usage Exchange Server Administration 1
K Export Organizational Forms Library Exchange Server Administration 1
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
Diane Poremsky How to clean up Outlook's Forms Cache New Slipstick.com Articles 0
X Bulk edit Contact forms Using Outlook 2
Diane Poremsky Designing Custom Outlook Forms New Slipstick.com Articles 0
Diane Poremsky Create an Organizational Forms Library in Exchange 2013 New Slipstick.com Articles 1
Diane Poremsky Publishing Custom Forms New Slipstick.com Articles 0
N How to disable user defined fields in BCM forms Using Outlook 2
N Passing Attachments between forms? Outlook VBA and Custom Forms 2
Nick Truscott Lost custom forms after moving mailbox Outlook VBA and Custom Forms 3
S How to remove forms from Organizational forms library Outlook VBA and Custom Forms 2
G Outlook forms text input Outlook VBA and Custom Forms 1
H Lost Custom Forms when we replaced Exchange Server Outlook VBA and Custom Forms 3
J Outlook 2013 Forms Issue Using Outlook 1
N Outlook Forms Not Displaying Outlook VBA and Custom Forms 6
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
D Move Personal Forms Library Outlook VBA and Custom Forms 10
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
K Outlook Crash on referencing forms Using Outlook 1
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
LarryH Custom Fields & Forms Using Outlook 3
