VBA Outlook Message Attachment - Array Index Out of Bounds
owensnw
Outlook 2019 64-bit
Having a bit of trouble with my code. The code has both a user form with a dropdown list to select the item being attached to the email. When I click the ok button I get "Run-time error '-2147352567 (800200009)': Array index out of bounds." I have tried everything, and can't seem to figure it out.
----------------------UserForm----------------------
Private Sub UserForm_Initialize()
With ComboBox1
.AddItem "Muni/Ind Line Card"
.AddItem "Food/Bev Line Card"
.AddItem "OPE W9"
.AddItem "OPE Credit References"
.AddItem "OPE Credit Application"
Private Sub CommandButton1_Click()
lstNo = ComboBox1.ListIndex
Unload Me
----------------------END UserForm----------------------
----------------------Module----------------------
Public lstNo As Long
Public Sub AddOPEAttachments()
Dim objItem As Object
Dim oMail As Outlook.MailItem
Dim myAttachments As Outlook.Attachments
If TypeName(Application.ActiveInspector.CurrentItem) = "MailItem" Then
Set objItem = Application.ActiveInspector.CurrentItem
Set myAttachments = objItem.Attachments
OPEAttachmentMenu.Show
Select Case lstNo1
Case -1
oMail.Subject = objItem.Subject
Case 0
myAttachments.Add "C:\OneDrive - Owens\Line Cards\Owens Pump Line Card.pdf", _
olByValue, 1, "Owens Pump Line Card"
Case 1
myAttachments.Add "C:\OneDrive - Owens\Owens\Line Cards\OwensFoodWine Line Card.pdf", _
olByValue, 1, "Owens Pump Food & Beverage Line Card"
Case 2
myAttachments.Add "C:\OneDrive - Owens\Owens\Financial\W9 2020 NEW.pdf", _
olByValue, 1, "Owens Pump W9"
Case 3
myAttachments.Add "C:\OneDrive - Owens\Owens\Financial\Owens - Credit & Bank References.pdf", _
olByValue, 1, "Owens - Credit & Bank References"
Set objApp = Application
Case "Explorer"
Case "Inspector"
Set objApp = Nothing
End Function
----------------------END Module----------------------
C Outlook 2016 - converting Word VBA to default Outlook message Outlook VBA and Custom Forms 0
R Outlook 2013 VBA I want to put the entire message to clipboard Using Outlook 5
M Outlook VBA Form not finding FOR LOOP -- Error message Outlook VBA and Custom Forms 2
S Excel vba code to manage outlook web app Using Outlook 8
G Outlook VBA and Google Calendar ("Events") Outlook VBA and Custom Forms 1
T Outlook AntiSpam with VBA Outlook VBA and Custom Forms 1
F "Move to" O365 feature to Outlook client via VBA Outlook VBA and Custom Forms 4
J VBA to switch Outlook online/offline Outlook VBA and Custom Forms 4
T VBA outlook, detect priority emails Outlook VBA and Custom Forms 5
S Outlook VBA Contacts Notes Outlook VBA and Custom Forms 0
O VBA or other solution for Outlook tasks to OneNote Outlook VBA and Custom Forms 0
S Automatically selecting folders and deleting messages in Outlook VBA Outlook VBA and Custom Forms 7
Diane Poremsky Outlook VBA: Use a Text File to Populate a ListBox New Slipstick.com Articles 0
C Saving Outlook attachments and links to attachments with VBA Outlook VBA and Custom Forms 2
Diane Poremsky Outlook VBA: Work with Open Item or Selected Item New Slipstick.com Articles 0
Diane Poremsky Working with VBA and non-default Outlook Folders New Slipstick.com Articles 0
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
Diane Poremsky Use VBA to create an Outlook Search Folder for Sender New Slipstick.com Articles 0
F VBA routine to write new sub routine in outlook Outlook VBA and Custom Forms 0
