Pls help to change the code for inserting date in Ol contact body
witzker
Here is the code
it puts a date AT THE TOP of The OL contact body
Pls help to put the date AT THE END of the contact body
Public Sub AddNote()
  Dim DefaultMsg$
  DefaultMsg = ""
  AddNote_Ex Application.ActiveInspector, DefaultMsg
Private Sub AddNote_Ex(Inspector As Outlook.Inspector, Optional Msg As String)
  Dim WdSel As Word.Selection
  Dim p&
  Msg = Format(Date, "mm/dd/yyyy", vbUseSystemDayOfWeek, vbUseSystem) & _
    ": " & Msg
  Msg = vbCrLf & "---" & vbCrLf & Msg
  Set WdSel = GetCurrentWordSelection(Inspector)
  p = Len(Msg) - 2
  WdSel.Start = 0
  WdSel.End = 0
  WdSel.InsertBefore Msg
  WdSel.Start = WdSel.Start + p
  WdSel.End = WdSel.Start
Private Function GetCurrentWordSelection(OpenInspector As Outlook.Inspector) As Word.Selection
  Dim Doc As Word.Document
  Dim Wd As Word.Application
  Set Doc = OpenInspector.WordEditor
  Set Wd = Doc.Application
  Set GetCurrentWordSelection = Wd.Selection
End Function
What to change
THX
regards
Witzker
WdSel.InsertBefore Msg inserts it before the current line. insertafter will insert it after the first line. IOf you want it at the end of everything, you need to move the cursory to the end -
WdSel.EndKey Unit:=wdStory
The format of the body line controls where the date is inserted
Sub StampDate()
Set Item = Application.ActiveInspector.currentItem
' first line
 '  Item.Body = Format(Date, "mm/dd/yyyy", vbUseSystemDayOfWeek, vbUseSystem) & vbCrLf & vbCrLf & Item.Body
'last line
   Item.Body = Item.Body & vbCrLf & vbCrLf & Format(Date, "mm/dd/yyyy", vbUseSystemDayOfWeek, vbUseSystem)
witzker
I do not know where to put this in the macro or what to replace PLS help.
Can you Pls put it in the macro I have posted?
If I use your macro
Sub StampDate()
The formatted body get lost!
e.g. lines in red get black again and format is lost!
Try HTMLBody instead of just Body.
You'd use my StampDate macro in place of your AddNote macro.
To keep using your macro, you need to add WdSel.EndKey Unit:=wdStory before the insertbefore line in your macro
WdSel.Start = 0
WdSel.End = 0
witzker
when I use StampDate macro
Sub StampDate()
Set Item = Application.ActiveInspector.CurrentItem
' first line
'last line
   Item.HTMLBody = Item.HTMLBody & vbCrLf & vbCrLf & Format(Date, "mm/dd/yyyy", vbUseSystemDayOfWeek, vbUseSystem)
Is Something wrong in the code?
I found this - loosing format:
What to try next?
witzker
WdSel.Start = 0
WdSel.End = 0
This works BUT
The next problem is that the focus is not at the cursor!
Meaning when I start to write the letters go There Were the cursor was before starting the macro.!
How to set the focus to the cursor position where the macro puts it?
B HELP! Using Outlook 4
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Help! My Contacts are being updated! New Slipstick.com Articles 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
J Can Anyone Help?? Outlook VBA and Custom Forms 1
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
A newb outlook macro help Outlook VBA and Custom Forms 1
X Help with custom form which is very similar to Tasks Outlook VBA and Custom Forms 6
P Outlook 2010: Missing tab - "Format/Picture Tools" HELP! Using Outlook 3
L Looking for help - want to try an alternative to Outlook? Outlook Wishlist 0
M Help! Can't set up IMAP for gmail Using Outlook 2
A Help with VBA please! Outlook VBA and Custom Forms 15
E Outlook Contacts Help Using Outlook 1
