VBA Cases with Listbox - Can you use Multi-Select?
Post number 4 has been selected as the best answer.
owensnw
Outlook 2019 64-bit
I currently have a VBA scrip that is running in Outlook where it pops up a listbox. The user selects the attachment, then it is added to the current email and unloads the user form. Now we are wondering if we can do multi-select and choose multiple attachments to go to the email. Here is the listbox:
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
If CloseMode = 0 Then Cancel = True
Private Sub CommandButton2_Click()
End
Private Sub CommandButton1_Click()
lstNo = ListBox1.ListIndex
Unload Me
Private Sub ListBox1_Change()
Private Sub UserForm_Initialize()
With ListBox1
.AddItem "-----------Credit------------"
.AddItem "OPE W9"
.AddItem "OPE Credit References"
.AddItem "OPE Credit Application"
.AddItem "----------Brochures----------"
.AddItem "Vogelsang Municipal Brochure"
.AddItem "Vogelsang Wine Brochure"
.AddItem "Vogelsang XR Buyers Guide"
.AddItem "Barnes Sithe Brochure"
.AddItem "Barnes SH Brochure"
.AddItem "Barnes Razor Brochure"
.AddItem "Barnes Pressure Sewer Brochure"
.AddItem "Barnes Upgrade Core Brochure"
.AddItem "Barnes Blade Brochure"
.AddItem "Barnes FRP Engineered Basins Brochure"
.AddItem "Mencarelli Wine Pump Brochure"
.AddItem "WasteCorp Municipal Brochure"
.AddItem "WasteCorp Industrial Brochure"
.AddItem "WasteCorp Double-Disc Brochure"
.AddItem "WasteCorp Self-Priming Brochure"
.AddItem "WasteCorp Pre-Packaged Lift Station Brochure"
.AddItem "BioGill Tower Plus Datasheet"
.AddItem "BioGill Ultra Datasheet"
.AddItem "BioGill Brewery Overview"
.AddItem "BioGill Food/Bev Overview"
.AddItem "ARO FDA / Food Compliant Pumps"
.AddItem "ARO 1.5 Inch Diaphragm Pump Cart Flyer"
.AddItem "ARO 2.5 Inch Diaphragm Pump Cart Flyer"
.AddItem "ARO Metalic Diaphragm Pump Brochure"
.AddItem "ARO Non-Metalic Diaphragm Pump Brochure"
.AddItem "Cloacina Product Card"
.AddItem "Cloacina Wine Introduction & Advantages"
.AddItem "Cloacina Wine Brochure"
.AddItem "Cloacina Mempac Mini Package"
.AddItem "Cloacina CEMPAC Thickener Brochure"
.AddItem "OpenChannelFlow Parshall Flume Brochure"
.AddItem "OpenChannelFlow Single Piece Shelters Brochure"
.AddItem "OpenChannelFlow Grinder Manhole Brochure"
.AddItem "AK Industries SS 1.25 & 2 Inch Rail Systems"
.AddItem "AK Industries SS 1.25 - 6 Inch Rail Systems"
.AddItem "AK Industries FRP Basins & Accessories"
.AddItem "Prime Solution RFP Family Brochure"
.AddItem "Prime Solution Simple Dewatering Solutions"
.AddItem "Prime Solution RFP Brochure"
.AddItem "Prime Solution RFP2.0 Brochure"
.AddItem "Prime Solution RFSP Brochure"
.AddItem "Prime Solution INT Thickener Brochure"
.AddItem "FOGRod Level Control Brochure"
.AddItem "FOGRod Level Control Presentation"
Then here is the code that calls for the object and has all the cases:
Public Sub AddOPEAttachments()
Dim objItem As Object
Dim oMail As Outlook.MailItem
Dim myAttachments As Outlook.Attachments
If TypeName(Application.ActiveInspector.CurrentItem) = "MailItem" Then
Set objItem = Application.ActiveInspector.CurrentItem
Set myAttachments = objItem.Attachments
OPEAttachmentMenu.Show
Select Case lstNo
Case -1
'oMail.Subject = objItem.Subject
Case 0
myAttachments.Add "C:\OneDrive - Pump\Pump\Financial\W9 2020 NEW.pdf", _
olByValue, 1, "NOTHING"
' Pump Information
Case 1
myAttachments.Add "C:\OneDrive - Pump\ Pump\Financial\W9 2020 NEW.pdf", _
olByValue, 1, "Pump W9"
Case 2
myAttachments.Add "C:\OneDrive - Pump\Pump\Financial\Pump - Credit & Bank References.pdf", _
olByValue, 1, " Pump - Credit & Bank References"
Case 3
myAttachments.Add "C:\OneDrive - Pump\Pump\Forms DOC\General Information\Pump Credit Application.pdf", _
olByValue, 1, " Pump - Credit Application"
objItem.HTMLBody = "See the attached credit application and return, or complete it online at the link: " & vbNewLine & vbNewLine & "<a href=""http://credit.pump.com"">Click Here</a>"
Case 4
'Vogelsang Information
Case 5
myAttachments.Add "C:\OneDrive - Pump\Venders\Vogelsang\Brochures\Vogelsang Municipal Brochure.pdf", _
olByValue, 1, "Vogelsang Municipal Brochure"
Case 6
myAttachments.Add "C:\OneDrive - Pump\Venders\Vogelsang\Brochures\Vogelsang Wine Brochure-sm.pdf", _
olByValue, 1, "Vogelsang Wine Brochure"
Case 7
myAttachments.Add "C:\OneDrive - Pump\Venders\Vogelsang\Brochures\Vogelsang XRipper Buyers Guide 2019-sm.pdf", _
olByValue, 1, "Vogelsang XRipper Brochure"
'Barnes Information
Case 8
myAttachments.Add "C:\OneDrive - Pump\Venders\Crane Pump & Systems\Technical\Barnes Pump\Brochures\Barnes Sithe Brochure.pdf", _
olByValue, 1, "Barnes Sithe Brochure"
Case 9
myAttachments.Add "C:\OneDrive - Pump\Venders\Crane Pump & Systems\Technical\Barnes Pump\Brochures\Barnes SH Brochure.pdf", _
olByValue, 1, "Barnes SH Brochure"
Case 10
myAttachments.Add "C:\OneDrive - Pump\Venders\Crane Pump & Systems\Technical\Barnes Pump\Brochures\Barnes Razor Brochure.pdf", _
olByValue, 1, "Barnes Razor Brochure"
Case 11
myAttachments.Add "C:\OneDrive - Pump\Venders\Crane Pump & Systems\Technical\Barnes Pump\Brochures\2020 Pressure Sewer Market Brochure.pdf", _
olByValue, 1, "Barnes Pressure Sewer Brochure"
Case 12
myAttachments.Add "C:\OneDrive - Pump\Venders\Crane Pump & Systems\Technical\Barnes Pump\Brochures\2020 Upgrade Core Brochure.pdf", _
olByValue, 1, "Barnes Upgrade Cores Brochure"
Case 13
myAttachments.Add "C:\OneDrive - Pump\Venders\Crane Pump & Systems\Technical\Barnes Pump\Brochures\Barnes Blade Brochure XP sm.pdf", _
olByValue, 1, "Barnes Blade Brochure"
Case 14
myAttachments.Add "C:\OneDrive - Pump\Venders\Crane Pump & Systems\Technical\Barnes Pump\Brochures\Barnes Engineered Basins Brochurepdf", _
olByValue, 1, "Barnes FRP Engineered Basins Brochure"
'Mencarelli Information
Case 15
myAttachments.Add "C:\OneDrive - Pump\Venders\Mencarelli Pump & Valve\Brochure\Mencarelli Inox Pump Brochure - Wine OPE.pdf", _
olByValue, 1, "Mencarelli Wine Pump Brochure"
'WasteCorp Information
Case 16
myAttachments.Add "C:\OneDrive - Pump\Venders\WasteCorp Pumps\Brochures\WasteCorp Municipal Pumps Brochure.pdf", _
olByValue, 1, "WasteCorp Municipal Brochure"
Case 17
myAttachments.Add "C:\OneDrive - Pump\Venders\WasteCorp Pumps\Brochures\WasteCorp Industrial Pumps Brochure.pdf", _
Case 18
myAttachments.Add "C:\OneDrive - Pump\Venders\WasteCorp Pumps\Brochures\WasteCorp Double-Disc Brochure.pdf", _
olByValue, 1, "WasteCorp Double-Disc Brochure"
Case 19
myAttachments.Add "C:\OneDrive - Pump\Venders\WasteCorp Pumps\Brochures\WasteCorp Trash Flow Self Priming Brochure.pdf", _
olByValue, 1, "WasteCorp Self-Priming Brochure"
Case 20
myAttachments.Add "C:\OneDrive - Pump\Venders\WasteCorp Pumps\Brochures\WasteCorp Pre-Packaged Lift Stations Brochure.pdf", _
olByValue, 1, "WasteCorp Pre-Packaged Lift Station Brochure"
'BioGill Information
Case 21
myAttachments.Add "C:\OneDrive - Pump\Venders\BioGill\Brochures\BioGill Tower Plus DataSheet.pdf", _
olByValue, 1, "BioGill Tower Plus Datasheet"
Case 22
myAttachments.Add "C:\OneDrive - Pump\Venders\BioGill\Brochures\BioGill Ultra DataSheet.pdf", _
olByValue, 1, "BioGill Ultra Datasheet"
Case 23
myAttachments.Add "C:\OneDrive - Pump\Venders\BioGill\Brochures\20180510BioGIllBreweryWastewaterTreatmentGuideVersion1.3.pdf", _
olByValue, 1, "BioGill Brewery Treatment Guide"
Case 24
myAttachments.Add "C:\OneDrive - Pump\Venders\BioGill\Brochures\20180606FoodBeverageOverview.pdf", _
olByValue, 1, "BioGill Food & Bev Overview"
'ARO Information
Case 25
myAttachments.Add "C:\OneDrive - Pump\Venders\ARO Pumps\Brochures & Flyers\ARO FDA Compliant AOD Pumps OPE.pdf", _
olByValue, 1, "ARO FDA & Food Diaphragm Pumps Brochure"
Case 26
myAttachments.Add "C:\OneDrive - Pump\Venders\Pumps\Brochures & Datasheets\1.5 TC AOD Wine Cart OP.pdf", _
olByValue, 1, "ARO 1.5 Inch Diaphragm Pump Cart Flyer"
Case 27
myAttachments.Add "C:\OneDrive - Pump\Venders\Pumps\Brochures & Datasheets\2.5 TC AOD Wine Cart OP.pdf", _
olByValue, 1, "ARO 2.5 Inch Diaphragm Pump Cart Flyer"
Case 28
myAttachments.Add "C:\OneDrive - Pump\Venders\ARO Pumps\Brochures & Flyers\EXP Metalic Pumps.pdf", _
Set objApp = Application
Case "Explorer"
Case "Inspector"
Set objApp = Nothing
End Function
This worked here - I used this for the button click
Dim i As Long
Dim lngCount As Long
Dim strPicks As String
  lngCount = 0
  For i = 0 To ListBox1.ListCount - 1
    If ListBox1.Selected(i) = True Then
      lngCount = lngCount + 1
      If lngCount = 1 Then
        strPicks = ListBox1.List(i)
        strPicks = strPicks & "," & ListBox1.List(i)
  Next i
    lstText = strPicks
'MsgBox lstText
    Unload Me
lbl_Exit:
these were my additems:
.AddItem "head2.csv"
.AddItem "head3.csv"
.AddItem "head4.csv"
I used the additem text as the select cases - split the array then got each file. If you can get the index #, of the Additem's you can use the case # instead -the command button code sample I had used the names, not the index # and I was too lazy to tweak it.
Public lstText As String
Dim StrArr() As String
If TypeName(Application.ActiveInspector.currentItem) = "MailItem" Then
Set objItem = Application.ActiveInspector.currentItem
UserForm1.Show
StrArr = Split(lstText, ",")
For i = LBound(StrArr) To UBound(StrArr)
MsgBox StrArr(i)
Select Case StrArr(i)
Case -1
Case "head2.csv"
myAttachments.Add "D:\OneDrive - Cdolive LLC dba Slipstick Systems\0 - Word\head2.csv", _
olByValue, 1, "head2.csv"
' Pump Information
Case "head3.csv"
myAttachments.Add "D:\OneDrive - Cdolive LLC dba Slipstick Systems\0 - Word\head3.csv", _
olByValue, 1, "head3.csv"
Case "head4.csv"
myAttachments.Add "D:\OneDrive - Cdolive LLC dba Slipstick Systems\0 - Word\head4.csv", _
olByValue, 1, "head4.csv"
Next i
Ah heck with it... this will use the case # - the additem list needs to be in the same order and you need to make sure the numbers are right. Using the same itemadd list in my other post, my 3 test files are #5, 6, 7
Private Sub btnOK_Click()
Dim i As Long
  lngCount = 0
        strPicks = i 'ListBox1.List(i)
        strPicks = strPicks & "," & i
  Next i
    lstText = strPicks
MsgBox lstText
    Unload Me
lbl_Exit:
owensnw
Outlook 2019 64-bit
Thank you!! Working perfectly!
Dim i As Long
  lngCount = 0
  Next i
    lstText = strPicks
MsgBox lstText
    Unload Me
lbl_Exit:
