Add VBA save code
Steve Mc
Diane provided me with this code to select an entire email message and save it all in a 12 point font.
It worked great. Thank you.
I would like add code at the end of this to save the email. What code instructions would do that ?
Thank you,
Steve
Public Sub FormatSelectedText()
Dim objItem As Object
Dim objInsp As Outlook.Inspector
' Add reference to Word library
' in VBA Editor, Tools, References
Dim objDoc As Word.Document
Dim objSel As Word.Selection
'Reference the current Outlook item
Set objItem = Application.ActiveInspector.currentItem
If Not objItem Is Nothing Then
If objItem.Class = olMail Then
Set objInsp = objItem.GetInspector
If objDoc.ProtectionType = WdProtectionType.wdAllowOnlyReading Then objDoc.UnProtect
' replace the With block with your code
With objSel
.WholeStory
' Formatting code goes here
'.Font.Color = wdColorBlue
.Font.Size = 12
'.Font.Bold = True
'.Font.Italic = True
'.Font.Name = "Arial"
objItem.Save
Set objItem = Nothing
Set objWord = Nothing
Set objSel = Nothing
Set objInsp = Nothing
JimG Use VBA to add <style> tag to Email. Outlook VBA and Custom Forms 2
N Get the seconds with userproperties.add method VBA Outlook Outlook VBA and Custom Forms 4
O VBA to change message format and add formatted signature Outlook VBA and Custom Forms 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
J Add categories to Shared Mailbox using VBA Using Outlook 2
R Limiting meeting attendees using VBA or an add-in Using Outlook 9
P Creating Add-in from VBA Outlook VBA and Custom Forms 1
J Add Multiple Attachments Sources using VBA in Word Outlook VBA and Custom Forms 6
H add an appointment for a custom calendar, vba excel Outlook VBA and Custom Forms 2
R vba rule exception "except with specific words in the sender's add Outlook VBA and Custom Forms 2
K Add Hyperlink in Email Body by VBA Outlook VBA and Custom Forms 1
B convert VBA code to Add-in Outlook VBA and Custom Forms 1
witzker Outlook 2019 Pls. add a Prefix for OUTLOOK 2019 here Using Outlook 1
